OK I'm a newbie and know very little about building amps but I saw this on Ebay and if the price is right why not??
Would this work as a sub amp transformer?? http://cgi.ebay.com.au/Transformer-2...ayphotohosting Regards Ted
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#2 |
how much current and voltage do you want to make?
do you need polar out puts? do you want to make a switching power supply or a standard linear type supply? you might ask the seller if the output is 52v across sec or 52-ct-52 making 104?or 26-ct-26... if it is 52 across the sec i might consider a straight full wave lc power supply at about 73 volts 52*1.414 or 26*1.414 =36 OR a full wave rect with a buck switch. this is obviously a 50 or 60 hz transformer so it can only be used as the input isolation transformer not the switching transformer. so more info will help the forum answer you. |
#3 |
Honestly don't know, I've sent query to seller waiting for reply.
It's just that I have some BIG smoothing caps here and it seems a shame not to use them somehow. So I guess thats a standard linear PS. I was looking for about 4/500 watts for a possible new party subwoofer box I may build. The caps I have here are "Marchon" and I have 6 of them, each 33kuF/63V, so I guess these won't work with 73Volts unless I use them in series. I was given a "rule of thumb" to use 100uF per watt of output, I was thinking that would be OK for 350 watts if the trannie had sufficient reserve
#4 |
I think this is a single secondary transformer 240:52Vac. This can only produce a single polarity DC supply. If you connect two half wave rectifiers to the output you can get low quality dual polarity supplies but I doubt anyone here would recommend that solution. Go buy a dual secondary or centre tapped secondary transformer. The highest secondary voltage you can connect 63Vcaps to is around 41Vac. 48Vac or 50Vac require 75V or 80V caps.
regards Andrew T. |
#5 |
it looks as if there are 2 yellow wires and a black on one side and 3 screw terminals on the other side. so it could be ct on both side or ct on one side with a Faraday shield, he'll have to see what the seller says, IF the seller knows.
nice piece of iron though, i might like it if it wasn't down under.......... |
| Supply for dual mono pre-amp | Tex Houston | Power Supplies | 3 | 17th May 2007 09:26 PM |
| Dual Mono vs Stereo Power Supply Question | bluegti | Chip Amps | 4 | 2nd January 2007 03:26 PM |
| Dual mono power supply's for the zappulse | micheat | Class D | 3 | 4th November 2004 06:46 AM |
| How "mono" is your mono power supply? | yldouright | Solid State | 21 | 24th November 2003 03:20 PM |
| Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 05:10 AM |
| Page generated in 0.08479 seconds (79.13% PHP - 20.87% MySQL) with 10 queries |
