Go Back   Home > Forums > Amplifiers > Power Supplies
Old 28th October 2008, 04:07 PM   #81
jamesrnz's Avatar
Default snubber
ok
i used a simple rc snubber here from drain to b+ although it seem to matter whether it went to gnd.
0.01uf and 3.9 ohm at 2w.
how much ringing and turn off spike is appropriate?
Old 28th October 2008, 06:00 PM   #82
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Hey, this is looking nice, at which load did you take the photo?
A few damped oscillations are ok, particulary if you can obtain them without too high losses in the snubbers.
It does not matter if the snubber goes to GND or to B+ as long as you have a short low impedance path from GND to B+ (obvious!)
You may find that turn-on EMI and ringing is easily reduced by reducing MOSFET turn-on speed.
I use to feel like the small child in The Emperor's New Clothes tale
Old 28th October 2008, 07:30 PM   #83
jamesrnz's Avatar
eva,
thanks, it is a result of your help and the other who contribute here.
this is at about 170 watts out for 30 minutes.
17.5 v a 9.5a , 2 ohm load.
the transistors and rectifiers get up to about 81f with a simple aluminum plate about 5.5x5.5x0.125.
the transformer gets to about 135f.
the windings are 66 wires of#36 which is 2640cm, which is 5.28 amps per 500cm, so i2r is getting too high.. i will have too add alot more wire if i am going to got to 42 amps.
( although i did hook it up to a 0.5 ohm load and the output dropped to 15.5 v at about 32 amps for about 3 secs before i took if off of the load, i'm allergic to plasma)
the snubbers are running about 95f.
(i have a little IR temp sensor)
i will rewind the transformer with more wires and spread them out. but im going to have to put a lot more on in order to get i2r respectable, since the inner windings wont cool well...........
Old 29th October 2008, 08:09 PM   #84
jamesrnz's Avatar
i wonder if i should use two of these power supplies at 20amp with the ft-140-77 with more wires and combine them in inductor with parallel windings,
i'm not sure i can get enough copper on this small core to handle the current i want. and a larger core would just get messy???
Old 1st November 2008, 12:13 AM   #85
jamesrnz's Avatar
iam adding a lot more wire to eachh core,, instead of 66 wires per turn i have crammed on 320
i will test this next week.......
i wonder if i should use two of these power supplies at 20amp each with the ft-140-77 with more wires and combine them in inductor with parallel windings,
Old 10th November 2008, 06:49 PM   #86
jamesrnz's Avatar
well i am going to get delayed.
i made another pcb
i made another transformer
BUT the BOSS called and I have to go back on the road for a few weeks, sooooo i am waiting to test the nigger transformer at least 25 amps only slightly warm is the goal............
standby , same bat-time, same bat-channel......
Old 10th November 2008, 08:11 PM   #87
Eva's Avatar
Hope to get news from you and this new prototype soon
Old 10th November 2008, 08:15 PM   #88
es44 is offline es44  Denmark
es44's Avatar
Oh dear, keyboard slips are quite common, but sometimes a little unfortunate
Cheers
Ebbe
Old 10th November 2008, 09:23 PM   #89
jamesrnz's Avatar
yep absolutely. i apologize to any one offended. should have been BIGGER....... fat fingers.
again sorry to anyone offended, none meant
Old 4th February 2009, 03:36 PM   #90
jamesrnz's Avatar
well i got stuck out on the road for a couple of months.
i will be back home in a week or two hopefully and after the honey doo's, i can get back to the project.
sooo... what would be the best ?
combine two switchers in parallel after the inductors?
or
combine two switchers in parallel after the transformer and two windings on the inductor?
or
parallell two transformers across one another using the same fets to drive and one inductor?
isolated or non-isolated psu for UcD in a car? zilog Class D 1 2nd February 2009 02:56 AM
What is the difference between an isolated IC and a non-isolated IC? DJ Exprice Chip Amps 16 20th June 2006 06:34 AM
Isolated RCA connectors for A40 gpsmithii Pass Labs 7 13th January 2004 04:53 AM
Page generated in 0.11403 seconds (70.92% PHP - 29.08% MySQL) with 11 queries
