Hi everyone.
I'm buildning a new tube based pre-amplifier and I would like to use a SMPS as the power source. I have read some articles around the net on designing SMPS powersupply, and it dosen't seem to be the easiest thing to do so I'm woundering if this has already been done by someone here or some design that woulden't be to hard to modify. I'm planning to put the PSU in a seperate cabinet, and I would need +300V around 300mA and +/-20V around 4A. Any ideas on this? /Johan Ch |
#2 |
Johan,
Check out the 28 JUL 2004 issue of Silicon Chip magazine. A regulated high-voltage tube power supply made from an old AT/ATX power supply....... Steve
#3 |
...Here's another shot.
#4 |
...and the control section.
#5 |
hi..i build a preamp for my soundcard with lm49710 opamps.it sounds good.i am using sennheiser hd25..i am using the PC's smps..its +-12 volts..but there is some noise.i am using 100n capacitors but there is still noise...which filter should i use?thanks
#6 |
hey I want to make this too
where is complete schematic for this project? |
#7 |
Yes- that's a BIG damn preamp!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#8 |
N-channel...have a PDF of the article around?
Regards, Aaron |
#9 |
Nope, sorry I don't. Just the pics and text.
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| FS : Battery Supply Tube Preamplifier (12V SMPS to 275V) | ANALOG GUY | Swap Meet | 0 | 30th October 2006 08:38 AM |
| SMPS for tube amp? | kubeek | Tubes / Valves | 15 | 20th May 2006 12:24 PM |
| SMPS & tube pre-amp development board. | ianl | Tubes / Valves | 2 | 10th April 2006 06:05 PM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 01:19 AM |
| Page generated in 0.09318 seconds (76.80% PHP - 23.20% MySQL) with 11 queries |
