Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th September 2008, 09:47 PM   #1
hollowman's Avatar
Default Anti-reverse-bias protection diode vs. performance
Due to the complexity of a CDP external PS project (and potential danger of accidentally reverse biasing ICs and ckts) I'm thinkig about placing diodes at the inputs of ckts and even IC PS pins.
How much performance loss (if any) can one expect in such an application if one uses, say, "high-quality" diodes (e.g., fast + soft recovery)?
Old 24th September 2008, 09:51 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi hollowman,
Normal robust diodes should work fine reverse biased across the supplies. Make sure you fuse the supply lines before your diodes.
I can't imagine what performance hit you could take from this, they represent a small capacitance across your supplies to common. Do make sure they return to a robust ground, right at the plug or socket.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 25th September 2008, 02:52 AM   #3
hollowman's Avatar
Originally posted by anatech I can't imagine what performance hit you could take from this, they represent a small capacitance across your supplies to common. Do make sure they return to a robust ground, right at the plug or socket.
(Thx for your reply).
Agreed: a robust ground is important. However, many of the ICs or ckts I use are not connected to Earth (plug/socket) ground; rather, they are digital ground, analog ground and even virtual ground for a headphone amp that that runs on battery/AC. Dunno whether it will make any difference in topic of this discussion (i.e., "Anti-reverse-bias protection diode vs. performance").
Old 25th September 2008, 03:55 AM   #4
anatech's Avatar
Okay, just return those diodes to whatever power supply ground you are using. Just avoid the signal ground for any data buss.
-Chris
Old 27th September 2008, 12:48 AM   #5
TechGuy is offline TechGuy  United States
The issue with using a blocking diode is when your using low input voltages, because of the voltage drop across the diode. A fast recovery diode may have a forward voltage drop of 1 V or even higher. This can be significant if your using low voltage batteries as your power source. The Soft-slow recovery (cheap diodes) would be better as blocking diodes because the usually have smaller forward voltage drops. In this situation reverse recover performance isn't an issue.
One option is to use a fuse and a blocking diode across the input voltage and input ground. The Diode will short and blow the fuse, but this solution isn't an option if your load requires high input current or you concerned about depleting your battery. If your fuse is set for a high current load, the blocking diode will blow before the fuse blows.
Another option would be a set of back to back N-Channel mosfets with low Rds. and use a small driver that is reverse voltage protected.
http://www.linear.com/pc/downloadDoc...41,P1385,D4142
You can also use off the shelf reverse recovery devices:
http://focus.ti.com/lit/ds/symlink/ucc3952-1.pdf
Old 29th September 2008, 12:15 AM   #6
hollowman's Avatar
Default Protection diodes close to IC supply pins
My main interest in adding protection diodes is to safeguard $$ and difficult-to-find digital ICs: PMD-100 (digital filter/oversampler), TDA1541A double-crown, etc. Hence, I'm thinking of adding protection diodes very close to the supply pins of these ICs. These ICs are already well bypassed with HQ caps, and the supply lines also have in-line ferrites.
Any thoughts on whether adding a protection diodes just before ferrites will degrade performance?
Extremely smart reverse polarity protection peranders Parts 5 15th January 2011 11:48 AM
Reverse polarity protection, better way without diode. guiseppim Class D 5 19th May 2009 08:44 AM
zener diode high performance Stefanoo Solid State 20 21st January 2007 06:15 PM
zener diode high performance Stefanoo Pass Labs 2 16th January 2007 10:11 AM
Page generated in 0.10479 seconds (78.05% PHP - 21.95% MySQL) with 10 queries
