Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th September 2008, 08:00 PM   #1
Ted205 is offline Ted205  United Kingdom
Ted205's Avatar
Default Filtering mains clicks/pops
I get a very annoying click/pop from my speakers when ever a light switch is switch on in the house.
Ive had a search around on the forums but couldn't find anything.
Is it just a case of putting a 100nf capacitor between L and N. Or a capacitor from both L&N to ground?
cheers
ted
Old 30th September 2008, 08:11 AM   #2
sunil is offline sunil  India
If it is "Gainclone" specific, these posts might help.
LM3886 very prone to mains noise
loud snaps from other devices switching
sunil
Old 30th September 2008, 10:08 AM   #3
Ted205's Avatar
excellent!
Cheers
Ted
Old 2nd October 2008, 01:05 PM   #4
Gordy is offline Gordy  United Kingdom
Also have a read-up on varistor / MOV / voltage-dependent-resistor:
http://en.wikipedia.org/wiki/Varistor
Old 4th October 2008, 09:07 AM   #5
you gain more by suppressing the interference at source.
Try adding an R+C snubber across the offending switch/motor/appliance.
These are available as integrated units, designed specifically for interference suppression of mains operated equipment.
regards Andrew T.
Old 15th October 2008, 03:11 PM   #6
gain is offline gain  United States
gain's Avatar
i have also seen the triacs in dimmer switches inject noise into audio circuits in certain instances, particularly if the audio device is connected to the same circuit the dimmer is on. cure was as Andrew suggested, bypass cap(s) at the source. ime a 0.1uF and/or 0.01uF has worked well.
EDIT: Just make sure the caps you use to do this are mains rated!
Minimizing pops and clicks with vinyl Jeb-D. Analogue Source 36 4th October 2007 08:47 AM
Mains pops and clicks markiemrboo Chip Amps 10 9th September 2007 09:57 AM
Clicks & pops with TDA1543 x8 DAC? fluckscapacitor Digital Source 19 18th November 2006 12:11 AM
SPDIF clicks and pops TBM Digital Source 8 11th June 2006 09:44 PM
Clicks and pops when turn dial on switchbox chris ma Everything Else 7 29th June 2002 05:53 AM
Page generated in 0.08934 seconds (78.32% PHP - 21.68% MySQL) with 10 queries
