strange sound from transformer when load increased
Old 18th September 2008, 09:47 AM   #1
jegandren is offline jegandren  Malaysia
Send a message via Yahoo to jegandren
Default strange sound from transformer when load increased
Dear All,
Attached is a voltage mode control SMPS,
I tested the circuit for 0A to 3 A load at +25V output no problem.
But as i increase the load more that 3A i notice there is a strange sound coming from the EE55 trannsformer.
Is this means that the transformer is running into saturation.
may be if i increase the value of bootstrap capacitor from 330uF/200V to 470uF/200v , would the sound from the EE55 transformer eleminate.
Old 18th September 2008, 12:16 PM   #2
zilog is offline zilog  Sweden
I suspect you are running the transformer into saturation. What Bmax are you aiming for during normal operation? Maybe you have left too little margin to allow for the feedback loop to swing when the input voltage drops due to output load.
Old 18th September 2008, 12:50 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Control loop instability or saturation of the output inductors or both.
Compensating the loop with a single pole (100nF capacitor at COMP pin) after the optocoupler is not a good idea, it should be compensated before the opto and a pole-zero is usually required.
Taking a look at the output of the error amplifier with oscilloscope may help in finding optimum compensation values.
I use to feel like the small child in The Emperor's New Clothes tale
Old 18th September 2008, 12:50 PM   #4
Dear zilog,
Attached is the transformer that im using.
Old 18th September 2008, 01:21 PM   #5
Now after some more inspection, I see that you are only taking feedback from one of the rails. Why not take feedback between +25 and -25 instead of only sensing one of the rails?
Regarding Eva's suggestion, you can use a TL431 to do compensation before the OC, I have attached an article explaining how below.
http://wintermute.csbnet.se/~zilog/f...31_article.pdf
Old 18th September 2008, 02:12 PM   #6
I took feedback from +25 V to 0V because, i have connected +25V only to the load and for the -25V i did not connect to any load.
Old 19th September 2008, 08:16 AM   #7
I have tested the SMPS voltage mode control untill 7.2A
( 180W ), and both the mosfet's stay cool and the switching rectifier at secondary part stay warm at 7.2A.
As I said there is some kind of noise or hum sound coming from the switching transformer is now eliminated, the switching transformer is silent now. I notice the hum sound when i tap the oscilloscope probe to both the mosfet's to see the switching pulse from drain to source, when the probe is removed from the mosfet there is no hum sound coming from the switching transformer.
Btw can anyone advise me on what measurements that i should consider for a SMPS.
Old 21st September 2008, 08:27 AM   #8
Fob is offline Fob  Bulgaria
Increase input caps. I thing they are insuficient.
Old 21st September 2008, 11:29 AM   #9
Default compensating the loop
I have done the compensation using TL431 before the optocoupler using this article http://wintermute.csbnet.se/~zilog/f...31_article.pdf
but i noticed that when i do the compensation using Cz,Rz and Cp as increase the load the output voltage drops say from 25.0V to 24.5 V .....
but when the Cz,Rz and Cp are removed then as the load is increased i still get the 25.0V.
can anyone advise on how exactly to do the compensation using Cz, Cp and Rz.
strange sound from transformer when load increasedHide this!Advertise here!
Help needed! strange sound from nmos quasi amp sanju21 Solid State 10 24th April 2012 10:03 AM
strange sound from my Threshold SA3 sometimes Tino Pass Labs 6 1st May 2009 02:54 AM
Cambridge Audio A3i - Strange Sound on Input carl.stock Solid State 1 6th December 2007 03:19 AM
Sound from dummy load? 2004ex Tubes / Valves 13 8th January 2006 06:19 PM
strange sound iceman Solid State 13 9th September 2003 03:46 PM
Copyright ©1999-2017 diyAudio
