Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th September 2008, 09:50 AM   #1
elnec is offline elnec  India
Default Newbie need help on SMPS
Hi all,
can someone give me some info how smps work and how can i make one.
i need two output from that smps which are +35v and +-15v
Elnec
Old 14th September 2008, 11:02 AM   #2
areza is offline areza  Bangladesh
you can start with the books
BROWN, M. (1990). Practical Switching Power Supply Design
BROWN, M. (2001). Power Supply Cookbook (2nd ed.)
Switching power supply design . ABRAHAM I. PRESSMAN
Old 14th September 2008, 11:25 AM   #3
Banned
smps + newbie = bad news.
Average 3-year electronics graduate still cannot design an smps.
The information is available through google anyway, or from manufacturers datasheets and application notes.
You need to start with building from an existing design. Better to start with a simple chip-amp and/or linear power supply.
w
Old 14th September 2008, 01:55 PM   #4
w
"Average 3-year electronics graduate still cannot design an smps." as for this, i am electronics graduate
can u give me a example of existing design?
Old 14th September 2008, 03:41 PM   #5
alvaius is offline alvaius  Canada
Elnec,
You can imagine why someone would assume that you are not an electronics graduate. Most electronics graduates would define the problem better than you have. An electronics graduate would also know how to research a problem such as what you asked and not ask such an open ended question for which the replies would be likely as open-ended and lacking value.
You have defined +35v, and +-15V. That is like saying I need a car, but not saying whether you need a toy car or a real car. What about input voltage, output currents, output ripple, etc.
You will find when you ask clear questions, you will get clear answers.
Alvaius
Old 14th September 2008, 04:54 PM   #6
Alvaius,
as i have not worked on power supply so i ask you ppl for some info on power supply
ok, Specifications are
input voltage : 220v to 250v at 50Hz
ouput voltage: +35v at 6A and +-15v at 1A
elnec
Old 14th September 2008, 05:20 PM   #7
Banned
Google > smps > 1st. line
Google > smps circuit > 1st line > SMPS Design > POWER SUPPLY SCHEMATICS FOR ENGINEERS AND HOBBYISTS - 12Volt AC-DC > schematic
w
Old 14th September 2008, 05:25 PM   #8
please dont get urself killed , buy a commercial unit or build a linear power supply, 240 watts off line smps in not something someone should build if don’t know how to keep things safe and how it works, smps is not something some one can master overnight ,
Old 14th September 2008, 09:38 PM   #9
mahmood is offline mahmood  Iran
Hi areza
look you need some informations about power electronic . for
example :
you msut know what's difference between MOSFET , IGBT and BJT
And how them drive and work . you must know about PCB
designing . just know about EMI . don't busy your brain on detail .
i was a man like U in 5 month ago . but now i can design a power
unit for myself project . i started with this attached schematic .
for the first step in google search , lookfor
switch mode power supply or SMPS topology .
discoverer is finder
Old 14th September 2008, 09:42 PM   #10
And this
13.6/20A new smps CHACALPOWERS Power Supplies 22 22nd October 2009 11:59 PM
SMPS 12v to +-70V gcds Power Supplies 3 19th January 2009 04:55 PM
4 - Smps - $75 Usd nodiak Swap Meet 8 21st November 2006 05:28 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.10751 seconds (80.01% PHP - 19.99% MySQL) with 11 queries
