Some body can provide me circuit diagram for SCR+ Transformer with electronics controlling 12v battery charger batter long battery life & charging even at low voltage 140vAC. (Explain one SCR BTA12 possible operate optocuppler and IC like LM324 circuit control input 220vac output 140vac transformer battery full charge then cut off charge) |
#2 |
Automatic 12V Lead Acid Battery Charger
http://www.aaroncake.net/CIRCUITS/charger2.asp for longer battery life you need a smart charger , a micro controlled pulse charger is the best way to go, |
#3 |
Dear saarcgsm,
You don't require scr to construct an intelligent and efficient battery charger and you should not venture in micro controller based charger, when even you are not aware regarding use of scr. Ensure controlled voltage and controlled current and utilize highcut and lowcut for battery voltage with simple zener. I think this simple configuration will be useful for you. In internet, you will get lot of schematics and try to select a proper one. If you want to have controlled voltage even when the input voltage is minimal, you can use ics from manufacturers like texas / linear tech or pi, and these will give you good result. These ics are very much available in Dhaka and not very costly. You have to work a bit. With thanks.
The tallest building in the world starts from the first brick. পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে। |
| New way of controlling mid range dispersion. | Snickers-is | Multi-Way | 6 | 21st April 2008 02:39 AM |
| Controlling power | phreeky82 | Parts | 2 | 10th August 2007 04:45 PM |
| Controlling transient response | AdamZuf | Tubes / Valves | 29 | 6th July 2007 01:38 AM |
| Controlling a relay with a PIC microcontroller | rtarbell | Parts | 9 | 12th October 2006 09:29 PM |
| electronic transformer | DJ_Looly | Power Supplies | 5 | 7th April 2005 09:11 PM |
| Page generated in 0.08508 seconds (73.43% PHP - 26.57% MySQL) with 10 queries |
