I'm tweaking a little tea2025 based amp found in a pair of pc speaker. Basically I'm playing with better caps, increasing capacitance, bypassing etc. Filter cap after diodes bridge was 1000uf, I put two 4700uf: the sound became fuller, with good bass but the little transformer (9VA-0,015a) heat too much. This is the first time I play with AC and transformers
I'm sorry I know I miss some basics... any help will be very appreciated Cheers |
#2 |
Did it Himself
The bigger capacitors needing to be charged will put more load on the transformer while at the same time preventing the rails sagging as much thus allowing the chip to provide more power to the load, thus taking even more out of the transformer.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
Ciao Calamaro
Too much capacitance in the power supply is not a good idea. Increasing capacitance causes shorther charging time, and bigger peak current in the trasformer and trough the diodes. A single 4700uF is enough. |
#4 |
You increased the filter capacitor by ~ x 10 ? and you do not expect trouble ? 2 x 4,700uF is just silly for a 5W max chip. 2,200 to 3,300 maximum I would say. /sreten.
#5 |
About the 7809: with a 12V trafo, you'll have a lot of heat from the 7809..... it need a big heat-sink
ps: your TEA2025 is not an HiFi chip. some improvements: -better and larger outputs caps on pins 15 and 2 (datasheet suggests 470uF, a 2200uF should give you better bass) -better input caps (polipropylene?) on pin 10 and 7 |
#6 | ||||
I don't understand: to have 9v from a regulator I need about 3 more v input then 12? Quote:
Ok, so as a filter cap I'll take just one 4700uF cap: but what about a new tx? |
#7 |
Hell,
do the maths. For regulated 9Vdc use a 10Vac or 11Vac transformer. If you can't find either then use 12Vac. The regulation of a tiny transformer can approach 30%. Your 10Vac becomes 10*1.414*1.3 = 18.38Vdc on no load. Subtract the diode loss of the rectifier and that leaves 17Vdc to feed the regulator. Now subtract the ripple on the smoothing caps and subtract the sag under load. Finally subtract the regulator drop out voltage at the maximum current you intend to draw. Is this final voltage more than 9V?
regards Andrew T. |
#8 | |
Hallo AndrewT, the maths are my problem
#9 |
You are going the wrong way. You are doing mostly irrelevant modifications to a piece of junk and imagining the results.
If you really want to learn and have fun, consider building a bigger amplifier with a pair of chip amps (like LM3886 or TDA7294) and a pair of 2-way speakers with 6,5" woofers.
I use to feel like the small child in The Emperor's New Clothes tale
#10 | |
10V AC (from trafo) --> (2*10*1.414) V Peak to peak; after ideal rectifier (with 0 voltage drop) --> 10*1.414 V; after a real rectifier (with 1.5V voltage drop on the diodes) and some capacitance --> (10*1.414)-1.5 V = 12.64V DC. ALL VOLTAGE on NO-LOAD CONDITIONS note: AndrewT add another 30%.... I suppose that very small tranformers have an higher output voltage for obtain nominal voltage under load, but I'm not sure. UNDER LOAD, I normally use 1.25 instead of 1.414 (square root of 2), so DC voltage is: (10*1.25)-1.5=11V DC (you could use it without voltage regulator) If you add a 7809 (about 2V drop): 11-2=9V DC (it means minimal losses in the regulator) |
| Have a smoking 60-0-60V transformer and looking for a project. | Shoog | Solid State | 11 | 16th April 2012 09:30 PM |
| CDPRO2 Group Project (open source project) | BrianGT | Digital Source | 147 | 8th August 2008 11:37 AM |
| Project for 1010VA 37.5V transformer? | downhere | Solid State | 32 | 23rd December 2001 01:18 PM |
| Looking for Amp project suitable for a 35V Transformer | ptrapp | Solid State | 11 | 2nd October 2001 05:28 PM |
| Page generated in 0.12652 seconds (80.57% PHP - 19.43% MySQL) with 11 queries |
