Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th September 2008, 12:35 AM   #1
redrabbit's Avatar
Default Opamp - Max supply check please....
I'm a little confused about the "single supply" rating of this opamp.
Can someone have a look for me ?
....I want to power it with +15v, -0V (circuit ground).
http://focus.ti.com/lit/ds/symlink/tlc2652a.pdf
=RR=
Old 4th September 2008, 01:27 AM   #2
theAnonymous1's Avatar
The max supply voltage is +/-8v, so that would be 16v for a single supply. Your 15v supply should work fine.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 4th September 2008, 03:22 AM   #3
redrabbit's Avatar
Thank you, mystery man.
Check my layout pls. for proper grounding (6 channel opamp pre) Groundloops Solid State 9 17th February 2008 08:35 PM
THAT transistor headphone amp (250ma discrete opamp) design sanity check. Russ White Headphone Systems 19 13th December 2007 12:52 PM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
Check out this power supply? planet10 Everything Else 3 18th September 2003 08:49 PM
Page generated in 0.07574 seconds (77.63% PHP - 22.37% MySQL) with 10 queries
