laying out dual output push-pull transformer?
Old 2nd September 2008, 08:50 PM   #1
zilog is offline zilog  Sweden
Default laying out dual output push-pull transformer?
I am in the process of deciding how to wind the ETD29 transformer for my center-tapped push-pull smps. The transformer will have two center-tapped primaries, and two center-tapped secondaries.
I guess the windings should be laid from the coilformer and up as: SPPS since only one primary conducts current at a time, while both secondaries carry current simultaneously (full-bridge rectification), and I want to minimize inductive energy storage between the windings.
The real question is how I should place the ends of the windings on the coil former, since each winding-half is calculated to fill one entire layer of the coil former, I cant get around having the (C) end of the primaries on the opposite side compared to the transistor-ends (A and B), the same goes for the secondaries, where S1 and S2 each fill one entire layer.
I have illustrated this in a sketch: http://wintermute.csbnet.se/~zilog/pushpull_ee_smps.jpg
Any suggestions as how to do this better? I would prefer to have all connections to the primaries on one side of the coil former, and all that belong to the secondaries on the other side, to give a clean separation of the smps in an input and an output half .
laying out dual output push-pull transformer?Hide this!Advertise here!
6C33B-C push pull with output transformer vincent_brient Tubes / Valves 20 5th June 2009 06:49 PM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Output transformer push pull om kalsoum Tubes / Valves 7 7th May 2007 09:48 PM
Push Pull Output Transformer wiring problem cyl Tubes / Valves 8 25th April 2007 02:23 AM
Transformer coupled 6SN7 push-pull DAC output stage? cathode_leak Tubes / Valves 7 24th January 2005 07:26 PM
Copyright ©1999-2017 diyAudio
