Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st September 2008, 08:54 PM   #1
TechGuy is offline TechGuy  United States
Default Dual LowSide gate Driver Current Doubling
Quick question:
Are there any issues by joining both channels of a dual low-side gate driver to double current output?
Old 4th September 2008, 01:05 PM   #2
I'm not familiar with the driver you are using, however, you will have some shoot through current because the switching times of the two sections will not be identical. The shoot through current could be very large and possibly overheat the driver if the switching frequency is high.
Old 4th September 2008, 03:58 PM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Use independent gate resistors or ferrite beads on each output to avoid strong cross-conduction due to slight differences in propagation delays. I'm doing that with IR4427 without problem.
I use to feel like the small child in The Emperor's New Clothes tale
Old 8th September 2008, 11:04 PM   #4
Thanks, I wasn't sure if small delay imbalances would have any ramifications.
Old 17th September 2008, 05:49 PM   #5
Tahmid is offline Tahmid  Bangladesh
Tahmid's Avatar
Use of independent gate resistors or ferrite beads on each output will protect shoot through current but the delay imbalance due to difference in propagation delay will hamper the proper functioning of the circuit in the long run.
Thank you TechGuy for interesting and thought provoking idea.
The tallest building in the world starts from the first brick.
পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে।
Gate driver simulation maverick_123 Class D 1 22nd September 2007 08:18 AM
3db increase by doubling driver count Bazukaz Multi-Way 53 17th July 2006 08:30 AM
Discrete Gate Driver Help!!! defragmenter Class D 1 23rd April 2005 06:48 PM
doubling driver numbers/spl gains? RobWells Multi-Way 63 9th December 2002 03:31 AM
Page generated in 0.09836 seconds (74.86% PHP - 25.14% MySQL) with 11 queries
