Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st August 2008, 05:59 AM   #1
pftrvlr is offline pftrvlr  United States
Default High current TL431?
The max 100mA current makes TL431 useless to my application. Is there a higher current version of TL431? Or can a external transistor be used?
Thx.
Old 31st August 2008, 06:18 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
Use an external transistor. I think there is even a schematic for this in the TL431 datasheet.
Old 31st August 2008, 06:19 AM   #3
Electrons are yellow and more is better!
peranders's Avatar
The answer is yes. Have you checked the datasheet? I'll recommend that you take a look at the end of it.
/Per-Anders (my first name) or P-A as my friends call me
Old 31st August 2008, 09:48 AM   #4
lineup is offline lineup  Sweden
lineup's Avatar
yes.
correct, amc184
for high current applications we use one Pass Transistor
with the TL431
Litterature, datasheet from Texas:
http://focus.ti.com/lit/ds/symlink/tl431.pdf
lineup
Old 31st August 2008, 04:56 PM   #5
xaudiox is offline xaudiox  Philippines
xaudiox's Avatar
what is the best transistor for 200mA application? thanks
Old 31st August 2008, 09:24 PM   #6
Thanks guys. I did look at the datasheet before, but I guess I was blind.
High voltage, high current super regulator, possible group buy peranders Group Buys 54 2nd June 2009 09:43 AM
high current vs high voltage power Clipped Car Audio 28 19th April 2007 06:06 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 01:32 PM
75% of rated max. current too high? bequerel Tubes / Valves 4 13th June 2005 12:22 PM
high volt/high current DIY home PS. deepanger Solid State 24 13th December 2002 12:17 AM
Page generated in 0.08201 seconds (74.33% PHP - 25.67% MySQL) with 10 queries
