(Transformer magnetic fields)
In a Linear app note, Jim Williams mentions.... ""An RF choke connected across a scope probe can determine the presence and relative intensity of transformer fields, aiding layout experimentation."" Linear Technology AN-9 (page 3) Can anyone explain a bit more on how to do this ? (coil type, size) (what to look for on the scope, etc) thanks, =RR= |
#2 |
search "Electromagnetic field sniffer" -- there are commercial probes, hall effect sensors -- folks have used parts of disk-drives, etc., etc.
Here's a "how-to" found on EDN: http://www.edn.com/archives/1998/060498/12DF_04.pdf |
#3 |
perfect, thanks!!
=RR= |
#4 |
I had this article printed out and found it yesterday -- reads Gauss directly with an Allegro linear Hall effect sensor -- the author gives a method of calibration:
http://www.edn.com/contents/images/6399102.pdf |
#5 | |
my Adobe reader cannot open this file nor the other pdf. What do I need to do?
regards Andrew T. |
#6 | |
![]() Worked fine for me.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 |
I'm on acrobat 7.0 and have just downloaded and installed the only update it offered.
It still can't open either of those pdf files. DaM_2005_4.pdf opened OK.
regards Andrew T. |
#9 |
Andy, PM me and I will send you the PDF -- are you using Mozilla as your browser?
Adobe is now mostly "bloat-ware" and "lurk-ware". |
#10 | |
Must be interference from electromagnetic fields. You'll need to make a "field sniffer". Catch 22. Regarding the first EDN article mentioned earlier.... http://www.edn.com/archives/1998/060498/12DF_04.pdf Am I interpreting it correctly, about the "cuts" that needs to be made ?? (I came up with an alternative method, if I can't find a thin enough saw blade....two pieces are cut, held in place at the proper distance, then soldered .) ![]() =RR= |
| Turntable Hunting | Dryseals | Analogue Source | 30 | 14th February 2009 09:19 AM |
| Driver Hunting..... | stuman | Multi-Way | 2 | 13th February 2009 04:31 AM |
| F R Driver Hunting | sdep777 | Full Range | 6 | 10th November 2008 02:20 PM |
| Happy Hunting Grounds | mobyd | Everything Else | 1 | 8th February 2006 05:01 AM |
| Hunting for a TV | Sawzall | Everything Else | 8 | 18th October 2001 11:20 AM |
| Page generated in 0.11089 seconds (78.56% PHP - 21.44% MySQL) with 10 queries |
