I have a 500VA transformer with 42Vac secondaries. Can i use this to power tl072 opamps which need +15 -15 Vcc and Icc at 1.4mA ? How should i do this ? Thanks.
#2 |
why would you do this?
this is no good! Get one 2x15 VAC or 2x18 VAC, like the size of 5-10 VA to power your TL072 op-amp Will not cost you much nothing. After 4 rectifier diodes you use Two IC regulators: 7815 and 7915 to make clean +- 15 Volt DC for op-amp (2x42VAC trafo gives close to 2 x 60 VDC after rectifier)
lineup |
#3 |
Hi
If you can, add two secondarys, first just few turns, so you can see how much turns will you need, then wind then up like any normal secondarys. And what ^^ he said, 15Vac is pretty much what you need, a bit lower too, if you don't really need +/-15V... as for power 2VA will be more or less overkill, since they produce enough current for everything, but if you go for a bit more it won't hurt |
#4 |
I use that 500 VA transformer for my subwoofer amp. So this opamps are part of an active crossover for the amp. I don't have space to put another transformer in thats y i thght of using the existing transformer.
Can i use a resistor to drop the voltage ? But i dunno how to calculate the resistor value as i do not know how much current must be made available to the opamp. |
#5 |
Hi
If you can't add secondarys, then use between + DC line, resistor and say 12 or 15v zener connected to gnd, this will produce + voltage for OPs. Same for other side...GND, zener, resistor, - DC line...As for resistor value, say you gonna load zener with 20mA so,.. R= U rail - U zener/I zener Don't forget to calculate resistor power |
| Better Opamp in QUAD 606/909 Power amp | arupg | Solid State | 14 | 19th September 2011 05:59 PM |
| Opamp based power amp | lumanauw | Solid State | 14 | 8th October 2007 05:46 PM |
| Opamp Power Amp - Will it Work? | jnmar | Solid State | 41 | 7th January 2007 01:13 AM |
| Regulate the psu of a power opamp with a similar power opamp? | Franz G | Chip Amps | 34 | 19th October 2004 10:49 AM |
| Page generated in 0.08579 seconds (75.14% PHP - 24.86% MySQL) with 10 queries |
