Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th August 2008, 04:25 PM   #1
Fob is offline Fob  Bulgaria
Default 160v/5a
So, I must bild 160V/5A from AC. I choose uC3844 on 400/2 kHz, BUP314, L1 = L2 = 30uH, Rs = 0.05 and passive RCD clamp. This is for test purposes, so I put all together with common in/out ground. It works up to 2A. But I have some sine ringing on current ramp over Rs. I make also current transformer - same thing. Also my IGBT burn quietly in lite loads. Any help please.
Old 6th August 2008, 05:51 AM   #2
This is the circuit.
Old 6th August 2008, 09:01 AM   #3
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Any ringing on Rs voltage waveform is going to be either current ringing from the transformer (resonance of leakage inductance and secondary side diode capacitance) or voltage ringing from the primary side (also due to leakage inductance and diode and IGBT capacitances). Ringing is particularly excited when the converter is operated in continuous-current-mode due to the reverse recovery of secondary side diode. This may be happening above 2A. Did you take that into account?
This IGBT is not intended to be used at 200Khz, 40Khz would be a more reasonable frequency. Excessive losses due to current tail may be causing it to blow, even at low currents. MOSFET may be a better alternative. Also, at 800W and 200Khz, a flyback converter is likely to require active clamping of the primary winding (after IGBT turn-off) because voltage spikes are likely to be quite high, like the amount of energy from transformer leakage inductance that needs to be either recycled or dissipated (.5*L*I^2 on each cycle).
There is nothing inherently wrong with a 800W flyback, you could make it work in the end, but a half bridge converter with the inductor for regulation in the secondary side is likely to give you far less headaches.
I use to feel like the small child in The Emperor's New Clothes tale
Old 6th August 2008, 01:25 PM   #4
Hi Eva,
Actually my question is addressed to you and few other people here so, thanks. I choose this topology because the output voltage is 160V and is more than half of rectified AC 220V. With half bridge I need boost transformer, in push-pull I need hard clamps, and in forward I need transformer bigger as in full bridge. So I decide that the Iprimary p-p is not so dangerous in flayback with pure current mode. I tried with IRFP460 and the heat is much less. Obviously you are right about BUP314, thanks again. And the ringing problem I find is more ground problem than parasitic caps.
What you thing for two transistor flayback? I never did that thing. What will happen to diodes during toff? Every thing what I read for this is said with half mouth.
Old 6th August 2008, 01:49 PM   #5
mflorin is offline mflorin  Romania
Hi Fob,
I would prefer a faster turn-off of mosfets with a local pnp...
http://www.st.com/stonline/products/...re/an/9172.htm
See the application note. It is a 2 transistor forward converter but it could be useful.
Old 12th August 2008, 09:15 AM   #6
ok, I need a litle courage to bild this! Any comment will be in help.
I reduce frequency to 50kHz and the IGBT driver is bipolar. Looks good in simulation but who knows what light and sound will produce. This must be a part from 100V Public Address amplifier.
Old 12th August 2008, 10:39 AM   #7
I think is something wrong with the .png file inside the archive...
Old 12th August 2008, 11:16 AM   #8
its ok, but Ill post *.pdf later, I am in 4PC in 4 places at time, sorry Flo
Old 12th August 2008, 03:34 PM   #9
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Nope works ok
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 12th August 2008, 07:36 PM   #10
Here is in pdf. I found error: there is no connector to emiterq jke ground is from simulation.
160v/8a Fob Power Supplies 50 10th December 2008 06:32 PM
WTB 160V caps. jazzy Swap Meet 0 7th June 2006 12:11 PM
Looking for 160V .... dsrviola Parts 10 1st July 2005 05:02 AM
24000µf/160V RIFA WALTER BURKHARD Swap Meet 5 28th June 2003 03:15 AM
Page generated in 0.11469 seconds (80.69% PHP - 19.31% MySQL) with 11 queries
