hi all,
From the circuit attached, lets say if the PFC ic is not connected to the AC to DC power stage. but the signal to the gate of the mosfet is given from a fuction generator of about 100Khz, i noticed the mains trips, suspecting the dV/dt would be high, so a snubber circuit is also attached. but yet the mains trips off. Actually when the swicthing occurs the circuit suppose to boost the voltage. please advise. Thank You |
#2 |
This is PFC, not boost converter. The signal must be modulated with 50Hz sine wave pulses. If you reduse inductance to proper di/dt value then may achieve boost.
#3 |
yes it is a PFC indeed...but if we look at the topology its actually a non-isolated flyback circuit. The non-isolated flyback turns on the MOSFET for a fraction D of the switching period, which, since it produces a voltage across the inductor, causes current to ramp up, storing energy in the inductance. When the MOSFET turns off, the inductor current goes through the diode and into the output capacitor and load. The non-isolated flyback should have a single output (there is no way to make more than one). The output is not isolated from the input and the output cannot be made less than the input voltage - even if you turn the MOSFET completely off, the output will equal the input (minus a diode drop).
Frequently people call the non-isolated flyback a 'boost' converter, which is not appropriate. but before connecting to the pfc ic (UCC3817) but the signal to the gate of the mosfet is given from a fuction generator just for testing purpose of about 100Khz, i noticed the mains trips... why? please advise |
#4 |
You have too large inductance for this frequency. She/he act like resistance wL
#5 |
so ur suspecting that the large inductance has caused the inductor to saturate and create a short circuit...so may be i should try with 100uH for a 100KHz switching frequency...is it if a lower inductance is used ..so it is lesser prone to saturation of the inductor. please advise.
#6 |
How much power you need?. Uo, Io, fs
#7 |
output current = 6A
output voltage = 380V switching frequency = 100 KHz |
#8 |
L = Ul*dt/di = ((380-270)*2.5uS)/(2*6A)=22uH
So you duty is 25% on 100kHz and DO NOT live this WITHOUT load!!!! You need current mode controll circuit....... |
#9 |
hi ,
can i know where did you refer for this formula, yet im not very clear about it. sorry for the trouble mate.. |
#10 |
The voltage acros inductor is proportional to speed of current change di/dt. This proportion is called inductance L. I suggest you to find some books and please dont play with 380 Volts before read them. This is a frendly advice, with all my respect to you. Please be carefull.
| Function Generator? | TheDriver | Parts | 4 | 18th August 2008 09:46 AM |
| Looking for an used function generator | Eva | Swap Meet | 0 | 21st February 2008 06:56 AM |
| function generator | d1camero | Tubes / Valves | 2 | 27th January 2008 06:26 AM |
| Have you seen my new function generator | jwb | Pass Labs | 1 | 28th August 2002 06:06 AM |
| Page generated in 0.08953 seconds (88.07% PHP - 11.93% MySQL) with 11 queries |
