Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st August 2008, 11:07 PM   #1
CHACALPOWERS's Avatar
Default +63/-63vdc Smps New Prototype
Hello SMPS builders and friends
This is my new SMPS for power amp aplication.
I like it but I will build a control current togheter
Thank you very much
Sandro
Old 2nd August 2008, 02:51 AM   #2
Send a message via MSN to guitar_joe
looks alright
can you say anything about how it performs though?
power, ripple, stability... that kind of stuff.
cheers
Old 2nd August 2008, 10:58 AM   #3
luka is offline luka  Slovenia
luka's Avatar
Send a message via MSN to luka
Hi
Good good, every time better, more and more clean look! Yea how about performance? Full bridge?
home page @ http://www.classdaudio.co.cc @ 24/7 all year long
I FEEL SLOVENIA
Old 3rd August 2008, 01:43 AM   #4
Hi guitar joe and luka
Great stability, very fine. It's a SG3525/2 inch. core/4 X IRGPC30U/ half bridge SMPS project. In the start, I built it with IR2110 but I don't understand, the IGBTs stay very hot no load and the IR2110 explode after few minuts. Now, I get out the IR2110 and built a small core driver. Very good enjoy because the IGBTs stay "ice" and no fan is necessary in hard load.
Thanks by your comments.
Sandro
Old 3rd August 2008, 03:03 AM   #5
what switching frequency did you use?
Old 3rd August 2008, 07:13 AM   #6
luka's Avatar
Hi
Also, after gate trafo, did you use any fast turn off circuit, or just resistor/diode?
If you have schema with IR, send it to me, will take a look and try to find why it did get hot and died...
I FEEL SLOVENIA
Old 3rd August 2008, 03:58 PM   #7
Hi dears
The gate switching is 55Khz and my project is based in this schematics:
http://i186.photobucket.com/albums/x...SMPSIR2110.jpg
Sandro
Old 3rd August 2008, 04:19 PM   #8
About the after gate trafo I use only 4R7 resistors less IN4148 or UF diodes.
Old 3rd August 2008, 04:28 PM   #9
luka's Avatar
Hi
It looks ok, maybe a bit too low R value, I would use 22R, practical is somewhere from 10R to 100R
Supply wasn't a problem because you have used 50Hz trafo, so voltage was ok.
Bad layout? But even so, I really don't know how you could make it that bad that IR would heat up and die.
I FEEL SLOVENIA
my new prototype zilog Power Supplies 5 25th September 2008 05:03 PM
prototype PCB's in the US mikelm Solid State 4 6th September 2006 01:20 AM
FS. ELNA Capacitors for Audio, 10000uF 63Vdc, 18 Pieces konstantin Swap Meet 2 12th May 2005 11:48 AM
2 Nippon Chemi-con caps. 100,000uF 63vdc mattjk Swap Meet 2 24th December 2004 06:11 AM
Page generated in 0.09543 seconds (76.26% PHP - 23.74% MySQL) with 11 queries
