Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st August 2008, 08:22 PM   #1
Default +- 30V from two dual +-15 supplies?
Greetings,
I have two surplus DC regulated power supplies; each of them has dual outputs of +-15V. I need one +-30V supply. I'm thinking about the following. In each PS tie the 0s of each output, this should give two supplies: +30 and -30, depending on what will be further referenced as 0. Then tie the 0s of these supplies to obtain +-30V PS.
Are there any caveats in this arrangement?
Thanks!
Old 1st August 2008, 09:17 PM   #2
Did it Himself
richie00boy's Avatar
Slightly confused by your words, but basically you need to connect the supplies in series with each other - negative of the 'upper' one to positive of the 'lower' one then this junction becomes your 0V poiint. But be sure to see first if any of the outputs is connected to earth. If it is then you can't do this as you will end up shorting one of the sides.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 1st August 2008, 09:59 PM   #3
OK, thanks!
Old 4th August 2008, 07:09 PM   #4
Hi richie00boy,
I managed to find the schematics of the outputs. It shows that the +/-15 are connected sharing a common return, so I can obtain 30V straight from +out and -out. So can I connect two such supplies in series for +/-30V?
Thanks!
Old 4th August 2008, 08:15 PM   #5
Did it Himself
Need to the the whole schematic! My concern is that COM terminal, it seems to be possibly connected to your +15 0 -15V midpoint. If this is then earthed through the case there may be problems connecting two supplies in series.
Old 4th August 2008, 08:31 PM   #6
Hi richie00boy,
This is the full schematics, it doesn't look like the COM is earthed.
Thanks!
Old 4th August 2008, 08:43 PM   #7
As Richie pointed out it depends on if the common 0 terminal
is floating or connected to earth. When you first hook these
supplies in seriese you might make this connection through
a 1/2w 10ohm resistor or a 1/2A fuse just to be safe.
Simple I'm Sure...Wiring 2 Single Supplies to Make a Dual relaxo Power Supplies 2 20th January 2009 10:06 AM
Single Supply to Dual Supplies edpgc Car Audio 0 22nd November 2007 10:36 AM
Parallel a dual power supply or two power supplies? Thunau Power Supplies 12 16th February 2007 04:21 AM
dual primary//dual secondary toroid larryg Chip Amps 22 6th September 2006 09:24 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Page generated in 0.09702 seconds (75.47% PHP - 24.53% MySQL) with 11 queries
