Go Back   Home > Forums > Amplifiers > Power Supplies
Old 31st July 2008, 09:17 PM   #1
jkeny is offline jkeny  Ireland
Banned
Default IEC Inlet Filter confusion
I rescued a Schaffner IEC inlet filter from an ADAT M/C before I sent it to scrap to put on some equipment. I put it on the inlet of a tube amp that I'm rebuiling. This amp has a turn on switch and before I use it I tested the power to ensure that all is OK.
Strange, I get a slightly lower voltage accross N & L when switch is off then when switch is on. This confuses me - is the current very low accross N & L when switch is off And high when switched on?
It is the FN 9246 High performance IEC inlet filter I have from here: http://www.schaffner.com/components/...22.asp?level=3$2$2&language_id=12&regUser=1&regUserID=-1
This unit has a 470K ohm resistor between L & N which would give rise to this reading? Just trying to confirm that all is in order & understand what's going on
Cap or caps on ac inlet ? ROVSING Chip Amps 27 2nd January 2011 07:38 PM
IEC Inlet with or without line filter for CD transport? pooya Digital Line Level 7 23rd August 2009 06:58 AM
IEC Inlet filter issue jkeny Solid State 23 2nd August 2008 04:31 PM
Wiring an IEC inlet mourip Parts 4 6th March 2006 12:52 AM
Replacing C7 inlet on the Panny 45 neilr11 Digital Source 0 25th December 2004 12:04 AM
Page generated in 2.28735 seconds (2.90% PHP - 97.10% MySQL) with 10 queries
