Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th July 2008, 08:16 AM   #1
Send a message via Yahoo to jegandren
Default Mosfet burn
hi all,
Based on the attached circuit AC - DC circuit, before conecting the PFC ic and the MOSFET and the i have connected my design...but without connecting the PFC ic . MOSFET( IRFP450) and fast recovery diode. I got a pure DC voltage about 320V for a load of 150 ohm's. But what i dont understand here is when i connect the MOSFET ...without giving any signal to the gate it should be functioning as the same, because current don't flow from drain to source when there is no signal to the gate. Here the case is my mosfets keeps burning as if it is shorted. please advise
Old 24th July 2008, 09:24 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
There is always some leakage from drain to gate so if you leave the gate open (or in an high impedance state) and apply some voltage to the drain, the MOSFET will tend to turn on by itself.
The gate has to be pulled low to source potential when the MOSFET is intended to be turned off.
I use to feel like the small child in The Emperor's New Clothes tale
Old 24th July 2008, 05:06 PM   #3
Heloo eva,
Thank you very much for your tips. It works.
Why burn in? sianturi Multi-Way 17 2nd January 2010 12:22 AM
Class-A-Burn: an amp with capacitive feedback divider around MOSFET Wavebourn Solid State 35 30th August 2009 08:41 AM
If output going to clip , will it burn the mosfet ?? titanchen68 Class D 17 25th March 2006 02:06 AM
Page generated in 0.07186 seconds (70.44% PHP - 29.56% MySQL) with 11 queries
