Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd July 2008, 07:57 PM   #1
pftrvlr is offline pftrvlr  United States
Default TL431 and SMPS Question
I have a few DVD SMPS that I want to use in other projects. Don't have much experience on the design of SMPS, just read a few short articles and studied few schematics.
The SMPS that I have has one TL431 - assuming used to regulate the output voltage. It has three outputs with different voltages. My question is like ths . If the 431 is monitoring only one output pin (I might be wrong on this one), how voltage on other pins can be stable if the current loads are all different?
Old 23rd July 2008, 09:38 PM   #2
carvinguy's Avatar
The TL431 could be using one or more voltages to set the regulation. It's possible to sum in all of the output voltages with different resistors into the TL431 to get the feedback.
Or... regulation is simply accomplished with the most heavily loaded output (3.3V? 5V? -not sure what the loads of a DVD player are) being sensed by the TL431 and the lightly loaded outputs (12V for example) being close enough due to the coupling of the secondary windings in the SMPS transformer. It's not going to stray much with a properly designed transformer. The key with this scenario is to sense the most heavily loaded output.
SMPS question shon35us Everything Else 0 5th March 2009 02:23 PM
SMPS question funky2x Power Supplies 5 23rd June 2008 11:34 PM
PC smps Question nicoch58 Power Supplies 19 25th November 2006 12:41 AM
TL431 Question vectorplane Power Supplies 2 5th March 2006 10:47 AM
Problem with TL431 in a SMPS Ultima Thule Power Supplies 32 2nd November 2005 06:36 PM
Page generated in 0.74542 seconds (6.59% PHP - 93.41% MySQL) with 10 queries
