Hi dears and DIY builders
This is my last power amplifier. It's not a BIG POWER, but there is a +45V/-45V regulated SMPS, and 3 + 3 output transistors (2SA1943/2SC5200) by side. Anohter side is about construction, Like Freddie Mercury say: "It's a hard life". Comments are always welcome. Thank you very much. CHACALPOWERS
#2 |
another pic
#3 |
another pic2
#4 |
heatsink waiting...
#5 |
Please tell us something more about the SMPS.
Maybe you could post the schematics? Enrico |
#6 |
Hi Enrico
My SMPS is based on this schematics: http://i186.photobucket.com/albums/x...G3525smps1.jpg The output regulation I change to 4N35 plus 2 IN4755 zener diode (43V) because I don't like opamp for output regulated. Regards Sandro |
#7 |
Sandro
Do you still use clean secondary ground for SG3525 and other circuitry? Seems to me, that when using optocoupler you can reference the whole driving circuit to mains neautral. Do you use any snubbers at half bridge mosfets? Regards Adam |
#8 |
Hi Adam
Excuse se by my bad english. I don't understand what is " clean secondary"...? And "snubbers" are ferrite beams in mosfet gates? About the opto, I only connect it is +/-output, less ground. The ground for KA3525 comes from a small transformer (200mA). The LIVE GND don't is together with it, it's all isolated. Regards Sandro (from Brazil) |
#9 |
Sandro,
Nice job on the finished project! Interesting output feedback sensing, the way the op-amps are employed. Question: Do you retain the op-amps and connect them to the opto, or just replace them wit the opto? I like the fact that you monitor both the (+) and (-) outputs. I have seen many opto-monitored outputs just monitor the (+) rail, and feel that symmetric monitoring offers a superior performance to the (+)-only mnitoring. Just my two-cents. Kind Regards, Steve
#10 |
The bad thing about the original schematic is that the gate driving transformer and current sense transformer are safety transformers at the same time.
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What Does Fostex "Rated Input" and "Music Power" | mark02131 | Full Range | 3 | 2nd January 2007 08:31 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.10892 seconds (73.25% PHP - 26.75% MySQL) with 11 queries |
