Hello,
I am thinking of making an inverter with 300w power. I have made the first step up stage from 12v to 310v. For the full bridge circuit, i want 2 use gate transformer to drive the 4 mosfets. Can someone help me in constructing the gate trafo...the turns ratio? Since, it is 50hz conversion, trafo has 2 b iron core, right? |
#2 |
use opto instead transformer for 50/60hz, or use discrete transistor driver or use one of the hi/lo bridge ic (ir2110)
Search the forum for power stage.pdf , its a nice h-bridge, |
#3 |
Are you sure a 2.2u cap can keep the hi side turned on for 10ms?
#4 |
may be 2.2u is enough , most important is layout , i had to layout few times to get it working with 20%-30% duty cycle, u may need to lower the voltage to 250-260v , also need to use A44 npn as well if u keep the voltage to 310v,
#5 |
Dear krej,
Not 2.2u, even 500u cap will not be able to keep the high side on for 10 ms, making virtual ground. Your all test and trial will be futile. IR2110 is for high frequency, not for Low frequency. It is safe and sound to use driver transformer. When you provide 12v to sg3525, the output will be 6 volt and you made a 1:2 normal linear transformer, so that you get 10v - 12v output in the driver transformer for mosfet gate drive. Transformer Winding: 180 turn in primary side with s.w.g. 34 wire for 6v input and 4x secondary output should be 400 turn each with same or s.g.36 size wire. It would be a small silicon sheet linear transformer. You must mark start and finish of primary and all the secondaries so that you can connect those 4 secondaries for 2 high sides and 2 low side in such a way that when 1high side and 1 low side is on, then other high side and low side is off and vice versa. If both the high side is on simultaneously, then you will loose all the mosfets as they will be shorted and destroyed. Other than transformer, you can use PVI safely for full bridge circuit. Thanks. ____________________________________________ IDEAS ARE MONEY IF THEY CAN BE USED ON GROUND. বাস্তবে ব্যবহারযোগ্য চিন্তাধারাই মানুষের প্রকৃত সম্পদ। |
#6 |
Thanks for the info.
| full bridge circuit help | Krej | Power Supplies | 1 | 20th July 2008 06:16 PM |
| Full Bridge X Half Bridge: What's The Best? | CHACALPOWERS | Power Supplies | 8 | 18th July 2008 05:45 PM |
| half-bridge VS. full-bridge | gearheadgene | Class D | 3 | 25th May 2007 09:49 PM |
| The difference of Push-pull,Half-bridge,Full-bridge | digi01 | Chip Amps | 0 | 8th September 2006 03:10 AM |
| Whats the difference between full bridge and half-bridge SMPS ? | skaara | Class D | 6 | 3rd February 2005 08:23 PM |
| Page generated in 0.10303 seconds (75.52% PHP - 24.48% MySQL) with 10 queries |
