Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th July 2008, 11:00 AM   #1
mflorin is offline mflorin  Romania
Default UC3846 current mode control vs. SG3525 with average current mode control
Hi all,
I am not familiar with SG3525 but I noticed that is used in a lot of designs and is quite cheap and easy to find.
I want to use it for a 1kW full bridge power supply and I want to avoid AC coupling of transformer due to size and cost of series capacitor(s). The usual choice is to use a current mode control PWM chip like UC3846 where sensed current is directly compared with output signal of Voltage Error Amplifier. The pulse by pulse current limiting is achieved by considering (correct me if I'm wrong) that voltage error signal does not change for two successive "ON" states.
My question is: Can average current mode control implementation avoid transformer saturation in a similar manner?
(sensed current is integrated, average value beeing considered as constant for two successive commutations ...) See attachment.
The internal error amplifier of SG3525 is going to be used as a follower.
I'm wainting for your thoughts ...
Old 8th July 2008, 10:33 PM   #2
Given that you are concerned about transformer saturation, you need to use pulse by pulse current limiting. Average mode as you have shown it, is too slow to protect the power switches.
Old 11th July 2008, 10:42 PM   #3
Claude Abraham's Avatar
Default re: 1 kW full bridge smps
I remember the SG3525 being *voltage mode control*, or "VMC", aka "direct duty cycle control". The 3525 is not current mode, neither peak nor average.
Regarding the use of VMC, a series cap is required to balance any volt-second asymmetry and prevent core saturation due to flux staircasing. If the SG3525 is used, a cap is needed. With *peak* current mode control, PCMC, a cap is not needed. In PCMC, the error signal sets the peak current and the duty cycle is indirectly controlled. The inner control loop which sets peak current prevents staircasing.
With average CMC, "ACMC", however, the peak of the current waveform can enter saturation, because the inner control loop is forced by the outer loop which controls the voltage, to regulate a specific *average* value of current. Thus, the average could be correct, but the peak enters saturation. Some ACMC control IC chips have a "volt-second" control feature to avoid this condition. If such a feature is not available, then a series cap would be a good safeguard against staircasing.
I hope this helps.
"We wish to reach the moon, not because it is easy, but because it is hard."
John F. Kennedy, 1917-1963, US President
Old 13th July 2008, 07:20 AM   #4
Thank you! both.
It helps me to take a decision....
Old 14th July 2008, 03:15 AM   #5
You can still sense current in the same spot and use current mode.
Old 14th July 2008, 10:13 AM   #6
switchmodepower - can you detail a little bit?
Old 14th July 2008, 12:42 PM   #7
The schematic you posted is not that much different (as far as complexity) than if you would use the 3846. So I'm not too sure why you are contemplating avg vs peak control.
Old 14th July 2008, 02:19 PM   #8
Sg3525 is a very cheap IC and I can buy dozens at corner street store.
The SG3525 "disadvantage" is that the error signal (output of internal opamp) is compared with oscillator ramp which has nothing to do with circuit conditions (i.e. sensed current). So, as already has ben told, it is a voltage mode control chip.
My thought was to include somehow in feedback loop the sensed current information in an attempt to prevent any possible flux imbalance in transformer core. This way I start thinking to conductance control.
UC3846 generates the PWM signal by comparing the sensed current ramp with the error signal from opamp output, so it is a current mode control IC.
The drawback is that I can't find it at local stores. I have to buy it online and the usual delivery time is round 2-4 weeks . Don't ask me why .
The idea behind is to use cheap an easy to find components.
Florin
Old 14th July 2008, 06:11 PM   #9
Anyway, Claude's explanation is right.
PHP Code:
the average could be correctbut the peak enters saturation
Old 15th July 2008, 01:42 AM   #10
Fob is offline Fob  Bulgaria
I already have made an acm ps 27V/30A with sg and opa. I think that saturation problem is more derived from asymmetry and acmode will correct this. The control is more pulse (slope) than average. I will post sch tomorrow.
current mode control classd4sure Class D 31 1st December 2011 05:50 PM
forward regulation of push-pull average current mode control? zilog Power Supplies 9 19th January 2009 06:06 AM
UC 3846 current mode control IC help jegandren Power Supplies 3 1st July 2008 04:41 PM
UC3847 current mode control IC doubt on Vref jegandren Power Supplies 2 29th February 2008 03:09 AM
Current Mode Control And Voltage Mode Control jegandren Power Supplies 4 26th February 2008 08:26 AM
Page generated in 0.12402 seconds (79.59% PHP - 20.41% MySQL) with 11 queries
