Has anyone ever used Digital isolators in SMPS design? The big advantage I see is the much higher switching speed, but I am curious if any has run into issues using them.
Thanks http://www.analog.com/en/interface/d...cts/index.html |
#2 |
I've used them for digital bus/control signal isoation in a strain gage amp, seem OK so far but I've not started testing EMI performance
read the app notes carefully, these do use magnetic coupling so it's possible putting them in a really bad spot could be problematic in a SMPS - know where your sw currents flow, and how far your magnetic component leakage fields reach |
#3 |
Hi
I have used them to pass the PWM signal (PWM controller placed on secondary side) over the isolation barrier to driver circuit. What I noticed is that at start-up when input side has an undefined supply voltage level (around 2 - 2.5V), the output generates some narrow pulses. Those pulses can trigger your logics if, for example, such a digital isolator is used on a fault line. It was the case of ADUM1100 but the manufacturer knows that behavior and I think they solved the problem by now (it happens about 2 years ago). |
| GB: Kerafol Keratherm Red Isolators (TO-220 / TO-247) | luvdunhill | Group Buys | 139 | 11th March 2010 07:23 PM |
| audio isolators how to | mhtplsh | Solid State | 0 | 24th May 2008 01:56 AM |
| High-Speed Digital Isolators? | Ryssen | Digital Source | 2 | 20th December 2006 07:42 PM |
| Pneumatic isolators | Prune | Everything Else | 2 | 18th February 2004 08:55 PM |
| Page generated in 0.07701 seconds (70.85% PHP - 29.15% MySQL) with 10 queries |
