Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th July 2008, 05:27 PM   #1
Send a message via Yahoo to jegandren
Default Common mode choke as boost inductor
Hi all,
Can i use a common mode choke 1mH as a boost inductor for my power factor controller.
Many Thanks
Old 4th July 2008, 06:04 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Consider that 1mH is the common mode inductance, and that it will saturate at a very low current. The leakage inductance (differential mode) is much lower, like 5uH to 50uH only, and it's air based so it won't saturate but it will produce an undesirably strong leakage flux. You need a dedicated boost inductor.
I use to feel like the small child in The Emperor's New Clothes tale
Old 5th July 2008, 04:13 AM   #3
Just to confirm, actually im not very sure the L1 in the circuit attached is a common mode choke or a boost inductor. please advise.
Old 5th July 2008, 05:18 AM   #4
wrenchone's Avatar
L1 is a boost inductor with auxiliary bias winding.
Old 7th July 2008, 05:43 PM   #5
N-Channel's Avatar
Send a message via AIM to N-Channel
....which is used to power the PFC chip after initial startup............
Common-mode choke discussion please stellavox Power Supplies 8 25th July 2009 12:00 AM
Common mode choke model eyalne Tubes / Valves 4 25th February 2008 10:22 AM
common mode choke question schiller Tubes / Valves 4 13th February 2008 09:34 AM
isolation transformer as common mode choke? av-trouvaille Power Supplies 3 4th July 2005 10:33 AM
Common mode filter choke... JojoD818 Solid State 11 27th November 2003 01:59 PM
Page generated in 0.08195 seconds (72.64% PHP - 27.36% MySQL) with 11 queries
