Go Back   Home > Forums > Amplifiers > Power Supplies
Old 2nd July 2008, 07:03 AM   #1
Tahmid is offline Tahmid  Bangladesh
Tahmid's Avatar
Default Voltage rating of p-channel MOSFET
I had a confusion on the voltage rating of p-channel enhancement MOSFETs. I have collected p-channel MOSFET :IXTH11P50 with -500v Vds from IXYS semiconductors. But in the datasheet it is mentioned that it has a Vgs of +/- 20v.
Since it is p-channel, current will go in through the source and out through the drain once the gate is pulled low. Here, both drain and gate are at ground level, so doesn't the MOSFET have to have a Vgs of -500v to be used at 500v?
I tested with 12v and 20v and the p-channels worked fine, but with 200v/300v they were not working properly, rather, shorted, with no gate control.
Why is this? If so, why is it mentioned -500v Vds in datasheet?
All help would be appreciated in this regard.
Thanks.
Old 2nd July 2008, 07:21 AM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Everything is right except your assumptions about how P-channel works. Think further
Tip: It's always Vgs what drives a MOSFET.
I use to feel like the small child in The Emperor's New Clothes tale
Old 2nd July 2008, 07:23 AM   #3
Tahmid's Avatar
I did not quite understand what you said. Could you please elaborate on what is wrong?
Thanks.
Old 2nd July 2008, 11:26 AM   #4
areza is offline areza  Bangladesh
working principal is same for both p and n channel fet, its the supply polarity changes to, +500v become -500v and +20v become -20v, so GND become +500v, +20v/0v will turn off the p channel , - 20v will turn it on, only n channel is superior then p channel,
Tip 2 , think again
Old 2nd July 2008, 11:30 AM   #5
Tahmid's Avatar
Is the -20v in reference to source or drain? (I think its to source as it is Vgs). But, if in reference to source, which in this case in positive, wouldnt -20v simply mean 20v in reference to drain?
Thanks.
Old 2nd July 2008, 01:42 PM   #6
Ouroboros's Avatar
No!
A P-channel MOSFET is connected just the same as an N-channel one, expect that all the voltages are -ve with respect to the 0V line.
So you have a 0V (local ground) that is connected (say) to the source. The drain is connected through the load to the -ve power rail (perhaps at -50V), and the important thing is that the gate is still driven with respect to the source, but is also at a negative potential. That is, you might have 0V on the gate (w.r.t source) to turn the FET off, and -10V (w.r.t. source) to turn it on.
Do a search for 'MOSFET complimentary source follower' or something like that on Google. I'll sure you'll find the relevant simple schematics showing you how things are connected.
Old 2nd July 2008, 01:47 PM   #7
Tahmid,
You are learning / trying to learn very fast. I appreciate your inquisitiveness.
Thanks again for your million dollar confusion. The answer is very useful for all mosfet users and I am sure, most of them will be benefited from the solution.
Data sheet is alright. vgs and vds ratings are also correct. Thing is that, you have to know the working mechanism of P- Channel Mosfet.
The rating for Vgs is correct and means that with the source at 500V, you cannot pull the gate to ground. You can use the P-channel at up to its rating (500V in this case; although, I tend not to go the maximum ratings). The point is that the gate cannot be pulled more than 20 V below the source. Thus, you need some way to level shift its drive.
Eva is correct- it is always vgs which drives a Mosfet. So, think about Level shifted PMOS Gate Drive. That will give you the solution. If you fail, solution will be provided to you.
Old 3rd July 2008, 08:10 AM   #8
Tahmid's Avatar
Thank you,
I got the point and am trying with level shifting method. I hope to make it soon and hope that my remaining p-channel MOSFETs will not blow up.
The tallest building in the world starts from the first brick.
পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে।
voltage rating for Ci? rfenergy Chip Amps 10 21st June 2008 09:24 AM
Using a cap above its voltage rating? h_a Parts 10 6th October 2007 03:46 PM
5 channel transformer rating for LM4780/LM4781 wjp007 Chip Amps 5 10th June 2007 12:12 PM
Transformer rating and using the ESP Mosfet Kit... PaulO-PEBoard Solid State 12 29th March 2007 08:45 PM
Where to buy a low gate voltage p channel MOSFET or make an alternative? Corn-Picker Everything Else 6 16th December 2003 10:15 PM
Page generated in 0.10742 seconds (78.36% PHP - 21.64% MySQL) with 10 queries
