Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th June 2008, 10:37 PM   #1
Default 12V - 60V smps
Hi.This is my first smps design and i need help. If you can help me i will use it on my car. And I KNOW it is not good system.This is my first
I found this circuit from another site. They are saying this can give 600w. I did this with EE-33's. I found them from pc power supply's.
Old 27th June 2008, 11:18 PM   #2
Sorry that was the old circuit.I couldn't edit the post.This is im using.
Old 28th June 2008, 03:57 PM   #3
Tolik is offline Tolik  Israel
Tolik's Avatar
Send a message via MSN to Tolik
As I understand, its regulated push pull topology.
So,
1. differential mode inductor between rectifiers and output capacitors MUST BE USED !!!
2. Input filter -single 22000uF capacitor... Are you able to get military grade cap with ESR & ESL low enough ? If not, go for 4-5x4700-6800uf , 16..25V regular caps.
3. Feedback loop. There is good idea to limit frequency bandwith before optocouplers, but not by connecting F depending loops to PWM`s EA. Much better to use single optocoupler, with differential voltage sensing by opamp.
4. Its good idea to add 2 small inductors, one from + to PWM control, the second from PWM control to ground. You will disconnect you most sensitive stage from AC RF/HF noise sources.
5. For just 600W I was going for single toroidal trafo. If SMPS should to power audio equipment, the toroidal or PM cores MUST be used, due to best shielding of magnetic emission.
Voltage mode control and push pull topology are not the best friends. Current mode controllers much more reliable.
Кто умеет делать - делает. Кто не умеет - учит. Х.Л. Менкен.
Those who can, do. Those who can't, teach. Those who can't teach, do research. H.L. Mencken
Smps a2005r2003 Power Supplies 19 11th August 2011 06:19 AM
SMPS for B+ from PC PS jkeny Tubes / Valves 1 10th February 2007 07:52 PM
Smps Juani_12-5 Car Audio 8 20th January 2007 09:15 AM
Smps rinox Power Supplies 0 2nd September 2005 10:05 PM
Need help on car SMPS DFI Car Audio 16 18th June 2004 05:59 AM
Page generated in 0.07727 seconds (71.90% PHP - 28.10% MySQL) with 10 queries
