hi everybody..we want to make a hi-end diy line filter for tube amps and general purpose amps..we want no dc humm,hiss and buzz..here in our country electricty is 50hz and sometimes dirty..and also i dont want to hear any cracking sound from speaker when turning on and off the lights..i have a schematic..i did this pi filter but there is still a sound when turning on my drill
#2 |
hi there..does anyone have an idea about it ? we need help
#3 |
that circuit is visually balanced but in reality is not balanced. The safety of having the blocking caps in both Live and Neutral lines is reduced compared to having all the blocking in either the Live line or in the Neutral line. It is better to have interference suppression fitted at source than to apply filters at the inputs to your equipment. Ensure all you domestic equipment is properly suppressed.
regards Andrew T. |
#4 |
hi andrew..thanks for your help..and i wanna ask something again..there is several mkps here in shops..
philips mkp X2 100n arcatronics 100n roederstein 100n hitano 100n i dont know about these capacitors..also i had wima mks but i think its not reliable for audio..which one should i buy ?or can you advice another one?it must be hi-end filter for expensive tube amps.. thanks a lot |
#5 |
Did it Himself
The capacitors across live and neutral must be X or Y rated. This circuit is nothing to do with audio as it's connected to the power supply, the mains at that, so ignore audio caps.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 | |
Do not use anything that is not rated for mains use. Must be X rated for Live to Neutral. Must be Y rated for Line (Live and/or Neutral) to Earth.
regards Andrew T. |
#7 |
should i also connect one more 100n capacitor between live to earth(not neutral) ? like this picture
#8 | |
It is better to use two Yrated caps, one from Live to Earth and the other from Neutral to Earth.
regards Andrew T. |
#9 |
#10 |
hi..sorry but i dont know what is X and Y rated capacitors..is it a specification ? there is not wima Y capacitors here in my country
| Which line filter is best? | Stu_M | Parts | 51 | 15th June 2009 12:34 PM |
| 60hz Line filter for PSU | triden | Power Supplies | 3 | 25th November 2007 08:58 AM |
| line filter design. | AudioGeek | Power Supplies | 3 | 9th April 2007 07:20 PM |
| Line Filter for Gainclone | Bassterror | Chip Amps | 2 | 1st October 2006 11:23 AM |
| Need Help with EMI/RFI Line Filter | auric | Parts | 10 | 29th August 2006 04:35 PM |
| Page generated in 0.11561 seconds (80.64% PHP - 19.36% MySQL) with 11 queries |
