Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th June 2008, 04:00 PM   #1
theAnonymous1's Avatar
Default Stealth vs. Hyperfast diodes
Which would be the preferred diode for 60hz rectification? I know stealth has a lower Vf drop, but it also has a higher recovery time. Is the recovery time even important at 60hz?
I'm sure there are other properties to consider that I am overlooking.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 24th June 2008, 08:01 PM   #2
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Reverse recovery is not important for 50/60Hz applications because di/dt is very low. Forward voltage drop is usually more important, but it's achieved at the expense of more stored charge and a longer recovery.
In 50/60Hz circuits the spike due to the brief reverse conduction is easily tamed with RC snubbers, as done in SMPS.
I use to feel like the small child in The Emperor's New Clothes tale
Old 24th June 2008, 08:39 PM   #3
Thanks Eva.
So does that mean that the stealth diodes with proper RC snubbers would be best?
I already have both types, I'm just trying to figure out which one to use.
Genesis Stealth Amp EchoWars Solid State 147 22nd December 2010 10:00 PM
SI- Stealth Mod Problem Davet Class D 9 23rd July 2006 12:28 AM
SI T-Amp Stealth Mod ? Wally Class D 1 10th June 2006 04:57 AM
Fairchild Stealth soft recovery fast switching diodes KevinLee Swap Meet 3 10th January 2006 09:53 PM
For Sale: Cerafine, Muse, Os-Con, Stealth Diodes and much more KevinLee Swap Meet 16 14th November 2005 05:58 PM
Page generated in 0.18492 seconds (28.98% PHP - 71.02% MySQL) with 10 queries
