-/+ 50 v SMPS
-/+ 50 v SMPS
Old 13th September 2008, 03:38 PM   #41
stcboy is offline stcboy  Saudi Arabia
Hi Mahmood,
Very informative and thanks i received your email, one question though what is the actual size of your board? again thanks for your reply.
Old 13th September 2008, 11:04 PM   #42
mahmood is offline mahmood  Iran
Default 12 V 30 A
hi
this is the pcb layout of my newly project in two part .
1st main board is power section & 2sd is PWM section
of course i used a few SMD components in PWM pcb
EDT 44
pri 36 [turn]
sec 4 [turn] " center tab "
pri wire size : 4*26 (AWG)
sec wire size : 33*26(AWG)
part one bottom side :
Old 13th September 2008, 11:07 PM   #43
Part two component side :
Old 4th January 2009, 02:18 AM   #44
sse is offline sse  Hungary
Dear mahmood,
I would like to build your smps(230V>+/-50V,SG3525,IR2110). Please send to me the pcb files, Thank you!
nincsmar@gmail.com
Old 17th January 2009, 08:59 AM   #45
microsim444 is offline microsim444  Jordan
Account Disabled
Default Current Ratings.
Hi Mahmoud.
Just one question after this long discussion,
Is this power supply stable for long time operation?
have you loaded it with fixed loads for 1 hour? to draw 6 amps? 4 amps?
what is the current rating for it?
It can deliver +/-50V 6 Amp continues?
Thanks...
Old 17th January 2009, 09:05 AM   #46
Account Disabled
Hi Mahmoud.
can you give more info about the transformer winding?
What is the meaning of 4 Turn center tap (33*0.4)
Thanks...
(33*0.4)
Old 21st January 2010, 03:13 PM   #47
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
-/+ 50 v SMPS
Originally Posted by kaulyn View Post
Olá Amigo ..........
Please, write in english only
No possible to approve posts I cannot read
Old 15th April 2010, 08:53 PM   #48
jash2008 is offline jash2008  India
jash2008's Avatar
This is a fascinating design and I built it using my own layout. I would like to share it with others DIYers. I modified it for different voltages.
The design works perfect with around 500W constant load with little rise in mosfet temperature.
Controller board is same for both designs
Old 15th April 2010, 11:05 PM   #49
Account Disabled
Thumbs up Jash2008
JASH2008
Nice Layout, Nice Work
Old 16th April 2010, 01:41 AM   #50
FELIBAR12 is offline FELIBAR12  Colombia
A lot of questions:
#Turns?
primary?
Secondary?
Etdxx?
awg?
tl494? or sg3525?
-/+ 50 v SMPSHide this!Advertise here!
SMPS for B+ from PC PS jkeny Tubes / Valves 12 15th May 2014 06:13 PM
Smps a2005r2003 Power Supplies 19 11th August 2011 07:19 AM
Smps Juani_12-5 Car Audio 8 20th January 2007 10:15 AM
Smps rinox Power Supplies 0 2nd September 2005 11:05 PM
Need help on car SMPS DFI Car Audio 16 18th June 2004 06:59 AM
Copyright ©1999-2017 diyAudio
