Hi Guys
Have question and plz someone help me to figure how to do . I made an SMPS using the TL494 from a schematic attached . the question is , To where should connect the remote ? thanks |
#2 |
The REMOTE line is connected to the Vcc of the chip, so presumably you need to put the chip supply on that to get it working. What does the data sheet say?
Jan Didden
/Another new issue: Linear Audio Volume 3! |
#3 |
Where did you get that schematic file from? I'm planning a push-pull converter myself, so I'm quite interested in such projects. Thank you.
-Juha |
#4 |
Hi ,
This signal can be connected to the Battery. Remote is a seperate supply if you dont want to use the battery power. Some systems have seperate aux power for controller operation. In this case i am not sure why they have used it as seperate input. you can short this with the battery. |
#5 |
The remote line should be loaded as little as possible. Some head units can't either handle too much current or too much capacitive load on the remote lead.
The best solution is to use a couple of transistors triggered by the remote signal to switch the power of the control IC and other circuits to +B.
I use to feel like the small child in The Emperor's New Clothes tale |
#6 |
Thank you Guys for the help .
First , Say's to connect the remote to car radio Antenna or to the accessory pin so that can tell to run when turn the car radio on. But this PS planed to use at home to power 2*100 watts 2* TDA7294 so there is no car radio to connect the remote with . am going to short the remote with the Battery + pin that will be permanent or install a switch between them to power on demand . The schematic got it from polish electronics producer . can post the PCB and the part list if interested . Thank you Diyer Great site to learn from . |
| SMPS question | shon35us | Power Supplies | 11 | 17th March 2009 10:51 PM |
| SMPS question | shon35us | Everything Else | 0 | 5th March 2009 02:23 PM |
| SMPS :noob: question | Low Rider | Power Supplies | 1 | 27th March 2008 03:17 PM |
| PC smps Question | nicoch58 | Power Supplies | 19 | 25th November 2006 12:41 AM |
| question regarding SMPS and UCD | cowanrg | Class D | 0 | 26th October 2005 06:19 AM |
| Page generated in 0.07487 seconds (73.96% PHP - 26.04% MySQL) with 11 queries |
