Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th June 2008, 07:20 PM   #1
kaosad is offline kaosad  Greenland
Default Zero Voltage Transition Problem
I am new to ZVS. I am wondering what circuit is able to sense zero voltage crossing. In one of my application a voltage can spike up to 400V.
Any suggestion.
Old 6th June 2008, 06:47 AM   #2
cerrem is offline cerrem  United States
A comparator.....You need to set the reference on the comparator for higher than zero to make up for the latency... It can also be a comparito modified for one-shot output with a quick reset upon a rising edge....
Chris
Old 6th June 2008, 07:40 AM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
First decide what kind of ZVS signal you need. A pulse at exactly ZV? Do you want a square wave that switches at ZV? In de last case, an opamp running without feedback is all you need.
Jan Didden
/Another new issue: Linear Audio Volume 3!
Old 6th June 2008, 03:10 PM   #4
A pulse for each ZVC, because I need it to be repeatable. Can an opamp able to handle high voltage and work in the range 100-200kHz?
Old 6th June 2008, 07:24 PM   #5
A few things to keep in mind....
You don't want to directly sense the high voltage....Your sense should be a fraction of the high voltage such as using a divider...
Using an open-loop Op-Amp for comparator operation will be unstable and ring.....
Chris
Old 6th June 2008, 08:21 PM   #6
janneman's Avatar
Well, of course you would use a bit of pos fb to get some hysteresis, but I thought that would be obvious...
So, an open loop opamps to make a square-wave with transitions at the ZC, followed by a 555-type one-shot to make it a pulse?
Jan Didden
Old 6th June 2008, 08:21 PM   #7
Yes, I can use voltage divider, but I have like a spike of 400V and then an oscillation of say 5V peak-to-peak which crosses zero point. Would the opamp be sentitive enough to detect that if I scale down the voltage too much?
Old 7th June 2008, 03:15 PM   #8
Hi again,
I figured out an idea, but still facing some issue. I use 12V zener diode to clamp the voltage. However, I must not affect the original signal in a direct way by leaking too much current. To fix this I put a large resistor in series with the zener diode. So, when the voltage goes pass 12V, the zener breaks down but would still leave the original signal intact, thanks to the resistor. This seems to work. But too large resistance distort the voltage across the diode (seen when the original voltage oscillates within 0-12V range) perhaps due to parasitic capacitance of the diode. A resistor greater than 10K Ohm distorts the voltage across the diode. I wanted to use 1 Meg Ohm or greater.
Anyone can recommend me a low parasitic capacitance 12V zener diode?
Old 7th June 2008, 03:45 PM   #9
janneman's Avatar
Originally posted by kaosad
Hi again,
You can use a normal small diode in conduction, then you can use a large series R. The voltage across the diode then looks as a about 0.6V DC with valleys at the zero crossings. Now put that into an open loop opamp + input (-input to gnd) and you have a beautifull zero xing square wave without loading the original signal too much.
You may need to put, say, 10mV DC at the -input from a supply divider to make sure it switches cleanly.
Add a 555 as one-shot after the opamp and you have your zero xing pulse. There are good apps in all 555 data sheets.
Edit: depending on the exact signal, you may not need the 555, the opamp itself may have a clean pulse. Try it.
Jan Didden
Old 8th June 2008, 06:58 AM   #10
Thanks janneman. That is a great idea!
I used silicon diode (in series with 1 Meg Ohm resistor) and I got smaller phase shift and good response time, but the the voltage won't go down below 200mV when the voltage dropped, not sure why. When I changed to Schottky diode, the phase shift was so much smaller and it dropped to slight negative. That is great!
Acceptable transition freq between dipole panel and boxed sub ? ashok Subwoofers 19 5th June 2009 05:58 PM
2Pi to 4Pi transition and box shape Moondog55 Subwoofers 6 7th August 2008 09:47 AM
Horn throat geometry: round to rectangular transition MaVo Multi-Way 20 26th November 2007 04:32 PM
how do you overcome low frequency radiation transition of line arrays? thadman Multi-Way 32 26th December 2006 03:19 AM
Voltage problem sith Tubes / Valves 10 7th January 2005 12:20 PM
Page generated in 0.09531 seconds (81.99% PHP - 18.01% MySQL) with 10 queries
