I brought my preamp from the USA to the UK and I have been using it with a step up transformer, which is horribly noisy, and I would like to eliminate it. I have opened the preamp and found that it has a pcb mounted transformer with four primary and four secondary points. On the primary side 1-2 and 3-4 are connected and then on the secondary side 1 and 4 go to preamp and 2 and 3 are not in use. Can I assume that this is a dual primary 115-0 115-0 trafo where the current USA configuration is: 1-2 115-115 3-4 0-0 and if the above is the case change bridging as shown below to make it UK ready: 1 115 2-3 0-115 4 0 I would like to post a drawing of the current physical connections and the proposed change but I do not know how to. I could e-mail it to anyone if that could be of any help. Many thanks Antonio |
#2 |
hi,
remove mains connection from 2 & 3. link 2 & 3. fit a mains light bulb in series with the primary. stand back and switch on. If the bulb lights, then 2 & 3 were wrong. If it stays off, then check your transformer secondary voltage. If OK, then remove the light bulb and you have a 230Vac powered pre-amp.
regards Andrew T. |
#3 |
Andrew,
Thanks again. I will do as you are suggesting. I forgot to mention that there is a small capacitor before the transformer in between the mains leads. Will I have to change this capacitor due to the new Vac ? Regards Antonio |
#4 |
a cap across the mains leads must be X rated @ 275Vac.
regards Andrew T. |
#5 |
Andrew,
It all worked fine. I made the changes and tested with light bulb. Now I have a 230Vac power noiseless preamp! Thanks again! Antonio |
| Using mains transformer as output transformer | Elias | Tubes / Valves | 175 | 3rd November 2009 08:36 PM |
| No mains transformer B+ ? | Salas | Tubes / Valves | 9 | 14th March 2007 11:04 AM |
| Toroidal mains transformer | bigwill | Planars & Exotics | 6 | 29th March 2006 08:18 PM |
| Mains Transformer Question | reticent67 | Parts | 14 | 6th September 2004 11:54 AM |
| mains wiring | ultrachrome | Parts | 4 | 8th March 2004 01:59 AM |
| Page generated in 0.06600 seconds (82.35% PHP - 17.65% MySQL) with 10 queries |
