Banned
I posted this in the Class-D area but no replies - it's probably more suited to this forum!
Has anybody tried this to reduce HF noise on SMPS. AFAIK cap mult acts as an inductor & so HF is attenuated more. Would this be a good way of removing the HF spikes on these PS? I'm thinking of improving my CD/DVD players as well as a digital amp that use SMPS The idea and some oscilloscope shots are here as part of an interesting discussion on how to improve 3 pin voltage regulators: http://www.acoustica.org.uk/t/3pin_reg_notes2.html |
#2 |
Why not? On certain audio circuits like preamps or opamps in general, it's good to have a lot of filtering. IMO you can never have too much filtering.
#3 |
Banned
Yea, my simplistic thinking on this was that most, if not all, of the noise on the supply of a SMPS tends to be well outside the audio band up around the switching freq & this is where a gyrator or cap multiplier has it's biggest attenuation.
I just wanted to check out with some of the SMPS experts here if there is any gotchas before I try it out on real equipment! |
#4 |
I wouldn't expect a capacitance multiplier to have very good attenuation at the >1MHz frequencies of interest. It should have the same problem as the 3 terminal regulators tested in that link.
And why would you need it? The cap values required are small. An RC or LC filter will work much better. |
#5 |
Else check AVX multilayer ceramic caps 20..50..60uf, specially designed for noise attenuation in SMPS. These can be found at Digy Key.
Кто умеет делать - делает. Кто не умеет - учит. Х.Л. Менкен. Those who can, do. Those who can't, teach. Those who can't teach, do research. H.L. Mencken |
#6 | |
EMC radiated emissions is a royal pain to tackle with SMPS... I have designed PWM chips with dither in the clock to spread spectrum the noise, thus lowering the amplitudes of the noise... The other option is to use quasi resonant circuit... cerrem |
#7 | |
#8 | |
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs! |
#9 |
EMI is mostly radiated by external wiring so metal enclosures are not of great help.
The most useful filtering is common-mode and its purpose is to keep input and output grounds at the same RF potential. Then differential-mode filtering attenuates the remaining RF components before they reach the wiring. A capacitance multiplier is mostly useless in comparison with a LC filter.
I use to feel like the small child in The Emperor's New Clothes tale |
| Capacitance Multiplier PSU | Ted205 | Chip Amps | 3 | 2nd March 2009 01:27 PM |
| Capacitance Multiplier on SMPS | jkeny | Class D | 3 | 29th May 2008 07:15 PM |
| Capacitance Multiplier | Kinnja | Solid State | 2 | 13th January 2008 08:12 PM |
| Capacitance Multiplier for A5? | siouxiebuff | Pass Labs | 3 | 21st January 2006 04:27 PM |
| Page generated in 0.11353 seconds (82.59% PHP - 17.41% MySQL) with 10 queries |
