See image for schematic..
I'm just experimenting with low noise 3 terminal regualtor replacements, so comments please on my mish-mash of various exisitng ideas / designs before I go knock one up. I think (*ahem*) I have incorporated a broadband bessel filter by using R9, C4, R2 & C1. God knows if this is a goer. Also not too sure of power source for the OpAmp. I've taken it from the 'clean' output via bead L1 a la SuperReg designs. Oh well, have fun ridiculing me Andy |
#2 |
Electrons are yellow and more is better!
Have you designed this by yourself? (seems that way)
I think the worst part here is the opamp if you really plan to use TL071. The opamp has more noise than the voltage reference. If you take supply voltage to the opamp from the output how do you plan to have a voltage at the gate of the mosfet that is 3-4 V higher than the supply voltage? One way to find out is to use LTSpice and simulate.
/Per-Anders (my first name) or P-A as my friends call me |
#3 | |||
Hey peranders,
Is LTSpice a freebie?? Schematic updated then.... |
#4 | |
![]() Check for example the noise. Many opamps today are significant better.
#5 |
go to Walt Jung's site and download the series of articles that he and Jan Didden wrote on regulators.
regards Andrew T. |
#6 |
This sch was taken from LC-Audio, of course it is modified a bit...
#7 |
These 'super' regualators are common knowlegde AFAIK, this is just a mish & mash of other people's ideas gathered from this site & other sources in an attempt to minimize it down to a mini-super reg to a TO220 size for linear reg replacement. Granted, LC Audio do this too.
I also tried to cunningly incorporate an active filter into the design, but this idea turned out to be utter bollocks when I modelled it in MultiSim... Update: |
#9 |
I see it as the connection header.
Join http://TurnMeUp.org |
| FFT Noise Spectrum of the LM7812 three terminal fixed voltage regulator | rjm | Power Supplies | 7 | 24th December 2009 03:59 PM |
| 3 terminal regulator with 3 terminal shunt reference | BWRX | Power Supplies | 10 | 12th April 2008 03:49 PM |
| Bad RCA terminal connection? | ninety | Digital Source | 3 | 5th September 2007 07:30 AM |
| RCA R35, 39 & 57 Terminal Usage... | mcelaj | Tubes / Valves | 1 | 3rd September 2006 11:14 PM |
| Page generated in 0.12606 seconds (77.26% PHP - 22.74% MySQL) with 11 queries |
