Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th May 2008, 07:04 AM   #1
adrianc is offline adrianc  United Kingdom
Default Advise on replacement transformer
I have purchased a power amp from the united states , an adcom gfa 5800 which was not duel voltage, i was unable to purchase a replacement from adcom , so i have had one manufactured here in the united kingdom, to work from our voltage 230v input.
the first one which was made had a short on it which i was told may have been caused by someone in the factry dropping it?? this caused a resistor and a couple of transistors to blow.
i sent this bak to them , and have recieved the replacemet. this should produce 81v per side , a total of 162v,checked from the service manual and the old transformer powered from a step down transformer, however the new one actually produces 172v . should i send it back again, of should this work satisfactoraly. Your help and advise would be most welcome.
Adrian
Old 13th May 2008, 11:53 AM   #2
An extra 5V on a 81V rail should not make much difference.
/sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 13th May 2008, 04:30 PM   #3
Minion is offline Minion  Canada
Did you measure the Voltage with a Load attached?? with a Load attached the voltage should drop somewhat depending on the regulation of your Transformer...
Old 13th May 2008, 05:50 PM   #4
hi minion
i have measured both transformers in a like to like comparisson, and the new one is 5v higher on the rails.
. i have had the amp on tonight and worked it hard , fingers crossed.
adrian
Old 14th May 2008, 12:14 PM   #5
AndrewT is online now AndrewT  Scotland
what was the voltage of the open circuited transformer and the mains voltage at the time of the measurement.
What is the DC voltage of the PSU with the amplifier properly biased up? Again what is the mains voltage at the time of the measurement.
What are the typical range of voltages on the PSU when you are working the amp hard? and again what is the range of mains voltages during this measurement period?
Now tell us if the transformer is the wrong voltage from what you specified.
regards Andrew T.
How do I tell whether a different replacement output transformer will be ok? digitallake Tubes / Valves 6 4th June 2009 09:51 PM
HV transformer replacement trans Planars & Exotics 2 14th March 2009 12:29 PM
toroidal transformer replacement Samuel Rock Car Audio 15 19th January 2009 02:04 AM
Replacement Transformer for NAD C352 bssmith Parts 0 19th February 2008 06:29 AM
Transformer replacement? ds21 Solid State 3 4th January 2003 10:00 PM
Page generated in 0.07736 seconds (74.30% PHP - 25.70% MySQL) with 10 queries
