Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th May 2008, 07:13 AM   #1
Send a message via AIM to Ductapemaster
Default Powering a PGA2310
Hi, I'm new to the forum...I'm working on a preamp based around the TI PGA2310 attenuator chip and I need some help with picking out a transformer that will supply sufficient current to power the chip. I have a +/- 15 volt regulator schematic already and I just need the xformer. How much power does the PGA require? My LM317/337's can't supply more than 1.5 amps each so I know I need that much or less from a transformer. Is an amp per rail sufficient? I'm trying to keep my preamp in a 2 inch tall box and I need to use the smallest transformer possible (and toroidal ones are really expensive for the specs I want).
Any suggestions?
Thanks!
-Dan
Old 10th May 2008, 07:22 AM   #2
peufeu is offline peufeu  France
Read the datasheet
A very small transformer will probably be sufficient.
Old 10th May 2008, 08:41 AM   #3
ifrythings's Avatar
+ 100mA would be over kill for that chip. It's idle current isn't even 15mA.
Old 10th May 2008, 09:16 AM   #4
Yeah the power LED will draw more current than the PGA2310, lol.
Old 13th May 2008, 02:49 PM   #5
Thanks a lot guys. I looked through the datasheet a few times and I didn't see anything like those numbers (except the idle current) but it's probably in there somewhere...
Awesome. This will save me some $$$
-Dan
Old 13th May 2008, 03:07 PM   #6
theAnonymous1's Avatar
Dan,
I have some small dual secondary transformers that would be suitable. They are Zettler Magnetics 44215. You can find them on this page.
You can have a few of them for just the cost of shipping.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
No microcontroller for PGA2310? louischia Chip Amps 12 4th March 2007 06:12 PM
PGA2310 noise fallow Digital Source 27 29th March 2006 06:59 PM
my own pga2310 pre-amp :) veteran Digital Source 22 31st August 2004 05:02 PM
pga2310 in parallel ? blu_line Solid State 3 18th August 2004 08:22 AM
CPLD vs. uC for PGA2310 ajm8372 Solid State 6 20th January 2004 10:40 PM
Page generated in 0.06419 seconds (84.37% PHP - 15.63% MySQL) with 10 queries
