I am building an exact copy of this amp and PSU combination: http://dogbreath.de/Chipamps/GainCar...nCardCopy.html and I have two toroidal transformers exactly like this one (see photo for exact specs and cables please): http://www.flickr.com/photos/1157168...7603119448350/ I want to use both toroids (one per channel) and if possible with the same simple bridge (with no caps, resistors, etc). I have found impossible to understand all the options and terminology, types, specs, etc regarding transformers, I never thought that bit could be that complex. If some one could help me I would be very grateful. Regards Antonio |
#2 |
what are the diameters of each of the wires forming the various secondary windings?
regards Andrew T. |
#3 |
Hi Andrew,
Primaries say: 20 AWG 300v Secondaries White Black White say: 20 AWG 600V All the other secondaries look like half the thickness (at least the plastic) and say: 22 AWG 300V Many thanks Antonio |
#4 |
20awg is about 0.813mm diam. At 3.1A/sqmm the rating for the 18-0-18 winding is about 1.6A giving 58VA for this winding. If the advert for this transformer did not mention the other secondaries or implied that the whole transformer VA rating applied to the 18-0-18 secondary then send it back at their cost. The current rating for the 22awg wires is based on 0.645mm diam giving an area of 0.33sqmm and continuous current of 1Aac. you can work out the VA rating of the other windings and check the total matches the claimed VA.
regards Andrew T. |
#5 |
Andrew,
Yes, I think I will re-sell or return these toroids. They are sort of smallish, light and a bit cheap really. I am starting as DIyer and will mess up with gainclones for a while in order to learn. I think I will invest in a couple of very good quality transformers (for dual mono) that would work well with my current and future projects without the need to upgrade them. Do you have any recommendation? Thanks Antonio |
#6 |
go to Rapid or Farnell or RS and buy your transformers from them. Alternatively, learn what you really need from a transformer and check Ebay frequently, there are bargains to be had from both new and second use toroids. But you do need to be patient.
regards Andrew T. |
#7 |
Many thanks Andrew
| newbie Q | memphissound | Multi-Way | 7 | 17th August 2006 11:36 AM |
| Yet another newbie | hell0un1verse | Introductions | 1 | 30th March 2006 05:31 PM |
| Newbie w/ sub ?'s | toenail | Multi-Way | 2 | 8th March 2003 01:10 PM |
| Newbie needs serious sub help | AcidRain | Multi-Way | 4 | 7th March 2003 07:07 PM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
| Page generated in 0.09553 seconds (70.04% PHP - 29.96% MySQL) with 10 queries |
