Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th April 2008, 09:33 PM   #1
Default Solving ripple....
Hey,
Well, first off, am I ever relieved!
I've been fiddling, and the best ripple I've found yet is 10V RMS, that's out of a 16uF->680R->220uF PI filter...any suggestions?
I'm thinking along the lines of - I'm well under the limit and it improves as per increase of filter cap size...so I'll pop a 45u in there.
Duncanamps PSUD gives millivolt-level ripple...but it fibs methinks.
I'm using GZ34.
L
Old 30th April 2008, 10:44 PM   #2
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
replace the 680 ohm with a choke with about the same resistance or add another cap and a choke so you will have cap choke cap res cap If it is for a preamp most of them will do because of the low current involved.
Old 1st May 2008, 06:58 AM   #3
I have a kinda-choke, an old toroidal transformer with 7.2H primary inductance. That said, I really ought to find a proper one.
I think I'll pop a larger initial cap in there and see what happens,
L
Old 1st May 2008, 08:42 AM   #4
Hello,
I think replacing the 16 with a 45 will not do a lot . switching from resistor will change a 6db filter into a 12 db. It will not cost a great deal of money especially if you buy them i a surplus shop. A few euro did do the trick in the past. Try it greetings, Eduard
Old 1st May 2008, 09:15 AM   #5
AndrewT is online now AndrewT  Scotland
what voltage and current are you working with?
regards Andrew T.
Old 1st May 2008, 09:16 AM   #6
Electrons are yellow and more is better!
peranders's Avatar
It seems to be very tube related
/Per-Anders (my first name) or P-A as my friends call me
Old 1st May 2008, 09:28 AM   #7
Psud predicts mV of ripple and you are measuring 10V of ripple.
What common mode voltage is in with the ripple.
How much of that common mode voltage gets through to the AC measurement?
Have you got access to a scope?
Could you take your ripple measurement through a high voltage isolating cap? Make sure the turn over frequency of the cap and meter impedance is well below the mains frequency.
regards Andrew T.
Old 1st May 2008, 11:51 AM   #8
will measure on tuesday, when I can get at a scope
Old 1st May 2008, 02:49 PM   #9
NONCE MOMENT #2!!!
Don't leave your input floating . That makes 50Hz hum
Other than that we have good sounding music!!!
RE the ripple, that was on the filter cap. B+ has <10mV
Old 2nd May 2008, 03:13 PM   #10
LOL
I think everyone here had assumed you meant 10mV of ripple when you stated 10V....
Page generated in 0.09235 seconds (77.43% PHP - 22.57% MySQL) with 10 queries
