Go Back   Home > Forums > Amplifiers > Power Supplies
Old 30th April 2008, 06:53 PM   #1
Default Bridge rectifier voltage question
I have a some 40v schotty rectifiers I would like to use in
a full wave bridge. How do I figure the max ac that a bridge
built with these can handel without exceeding that 40v rating?
I figure that used in a halfwave circuite the max would be ~
14v ac I kind of expect the fullwave configuration would
still have a 14v ac limitation. Kind of related to this I seem
to rember that schotty rectifiers can't be put in seriese for
higher voltage am I right about this?
Old 1st May 2008, 01:47 AM   #2
Highest voltage you can use is 40V peak then. (28.28V RMS) I'd recommend 25V or less because it's not hard to kill a rectifier due to overvoltage. IMO high voltage kills the diode easier than high current. I found that out after killing a 45V part.
40V is way low, sounds like it was for 5V or 12V supply. Try a high-voltage super fast diode like MUR3020 or MUR3060. The 3020 is 200V and the 3060 is 600V, both are 30 Amps.
bridge rectifier question crippledchicken Power Supplies 31 25th April 2008 12:17 PM
Bridge Rectifier question hotscot Power Supplies 14 15th January 2006 05:15 PM
Bridge Rectifier Question sam9 Solid State 3 16th October 2004 02:03 AM
Page generated in 0.06550 seconds (67.09% PHP - 32.91% MySQL) with 10 queries
