#51 |
K,
is there a post detailing your measurement system? 1uV to 10uV is mighty impressive. |
#52 |
would be useful if the Y-axis was in dBV. Is the instrument's noise floor (for comparison) shown in slide #1?
#53 | |
Ken |
#54 |
Plots with vertical scale at Vrms. First plot is overall bandwidth 0 to 100kHz second plot is limited bandwidth 0 to 2kHz. I have put a common mode choke and film cap in line prior to the regulator which killed any 60hz related artifacts.
Ken |
#55 |
Finish my build of Per-Anders SSR-02. Results at 0-100k look very nice, note the vertical scale is 0 to 10uVrms. But, when looking at 0-2k, not so nice. Regulator is fed from identical supply configuration as the LME49600 regulator. It is not placed in a shielded box, but, neither was the LME regulator. Maybe I have something wrong...
Ken |
#56 |
The very high gain of the SR means that they are susceptible to excitation. That's why some have had issues with the AD797 in this application.
For noise measurements, you should really use a battery. The battery and regulator and any local amplifier should be shielded and grounded. You should also baseline the measurements -- to get a handle of the SNR of your system. attached is a snapshot of a run I did for the Sjostrom regulator last March Left scale is nV/RtHz |
#57 | |
Best, Ken |
#58 | |
Take a look at Walt Jung's articles -- archived on his site Home |
#59 |
Walt Jung has recently posted part four of his 1995 SuperReg series by Gary Galo for those interested. http://waltjung.org/PDFs/Regs_for_High_Perf_Audio_4.pdf
#60 | |
| Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) | hollowman | Power Supplies | 44 | 7th October 2009 07:01 AM |
| Why are they building -15v regs | RCruz | Power Supplies | 16 | 14th December 2008 10:14 PM |
| Jung Super Regs & LEDs | underwurlde | Power Supplies | 9 | 14th May 2008 02:24 PM |
| Audiocom super regs | t. | Digital Source | 10 | 20th April 2007 04:16 AM |
