#21 |
Looks very nice Jack, I'm looking forward to some results from you. I've looked into using a high performance opamp buffer in a different regulator as well, but then dropped the idea. Is the lm4040 a reasonably low noise reference in reality? I have no experience with it.
#22 |
#23 |
Electrons are yellow and more is better!
LM329 is one of the best and it's a mystery why you can't find any similar in SMD package.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#24 |
I wanted to use what I had on hand -- and the one reference I had in SOT-23 was the LM4040 which, by coincidence, Nat Semi used as well. I also used through-hole rectifiers!
Will see how we do when the stuff comes back. I have stock Super Regulator boards from Old Colony to compare noise, impedance etc. |
#25 | |
#26 |
Well, the first try ran over a cliff and died -- I got one version to work right for a few seconds -- then it oscillated itself to death.
#27 |
Jack, is this your new reg? I meant to ask how it was coming along.
#28 | |
I strongly suspect that it is a layout issue, since all of the connections are correct per the schematic. I did have a layout issue with the SOT-23 LM4040 which I fixed. |
#29 |
Did you use an output cap at all? There's also Jimmie D. Felps' trick with the small resistor in series with the output, for stopping crazy opamps oscillation (applies only to driving capacitive loads, but worth trying because it's so easy).
#30 |
Jack, when I see your grounding scheme, how did you think? You have made a dual PS with two separate ground connections? Grounding is critical you know.
| Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) | hollowman | Power Supplies | 44 | 7th October 2009 07:01 AM |
| Why are they building -15v regs | RCruz | Power Supplies | 16 | 14th December 2008 10:14 PM |
| Jung Super Regs & LEDs | underwurlde | Power Supplies | 9 | 14th May 2008 02:24 PM |
| Audiocom super regs | t. | Digital Source | 10 | 20th April 2007 04:16 AM |
