Super Regs
Super Regs
Old 12th May 2008, 02:18 PM   #11
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Super Regs
LME49600 -- yes, it is a buffer -- and a mean looking one at that.
Old 12th May 2008, 02:24 PM   #12
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Super Regs
Do you plan to use the LME49600 as an output element?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 18 pcb's in interest.
Old 12th May 2008, 02:46 PM   #13
jackinnj's Avatar
Super Regs
Yes, I am going to try it...I then compare vis a vis the Old Colony Super Reg with the AD797, 825, LT1115 etc for noise and impedance.
Old 12th May 2008, 03:15 PM   #14
peranders's Avatar
Super Regs
A possible improvement is that the buffer is faster than the D44H11.
Old 14th May 2008, 01:03 PM   #15
The "must read" are the series of regulator articles on the Walt Jung site.
Read and re-read and ask until you understand the full content.
regards Andrew T.
Old 15th May 2008, 01:46 AM   #16
jackinnj's Avatar
Super Regs
The articles by WJ and our own Janneman were in AudioXpress in 1995, and WJ had a smaller article in EDN a little later -- I can always get Mr. Didden's attention by quoting him to the effect of:
"It oscillates now what???"
Old 15th May 2008, 07:44 AM   #17
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
You read my mind or what ?
I just read a comment by Scott Wurcer, the designer of the 797, here:
http://www.diyaudio.com/forums/showt...64#post1509264
Wish I had know that at the time...
Jan Didden
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 3rd November 2008, 09:50 PM   #18
Digitalscrap is offline Digitalscrap  United States
Originally posted by jackinnj
I've got my parts (LME49600 etc) and am going to compare to the Jung/Janneman etc boards from AX and my own PCB's with the AD797 and AD825.
The LME49600 only became available at DK and Future within the past few days.
Curious if you had made any progress on testing various regulator configs?
Old 19th September 2009, 02:34 PM   #19
jackinnj's Avatar
Super Regs
Almost a year later, here's the version I am going to work with -- mostly surface mount, save the rectifier diodes and electrolytic caps -- I have not had a lot of success mounting smt electrolytics. The reference for each is the LM4040:
Old 19th September 2009, 02:43 PM   #20
peranders's Avatar
Super Regs
A trick if you are going to solder those by hand: Make the pads so they are visible with room for the solder iron tip.
Put fresh tin on the cap
Put tin on a pad and let the cap slide in with the tin still melted.
Solder the other pad.
My latest SMD design is the SSB01, diamond buffer and here I have enlarged the pads somewhat. It the moment I can't reach my homepage but you can try later on to take a look at it.
Jack, I recommend wider power traces and you could also go for ground plane with special care taken to the signal ground at the right.
Super RegsHide this!Advertise here!
Simple Super Shunt and Simple Super Shunt w/CCS vs. JSR03/05 (and other series regs) hollowman Power Supplies 45 5th July 2013 11:50 PM
Why are they building -15v regs RCruz Power Supplies 16 14th December 2008 11:14 PM
Jung Super Regs & LEDs underwurlde Power Supplies 9 14th May 2008 03:24 PM
Audiocom super regs t. Digital Source 10 20th April 2007 05:16 AM
