hi guys im about to build a new amp kit from aussie amps and ive got 4 x300va 40 0 40 transformers .my question is can i join them together some how to get 2 x 600va transformers without increasing the voltage . my old amp a gb 300 was happy to run with the 300va toroids .1 per channel but the new amp would be better with 600va per channel or more so i was hoping to use the toroids i have somehow instead of buying new ones . cheers
#2 |
I don't think so. . . parallel connection with any imbalances could be
problematic. . . two different cores. |
#3 |
I cannot see the problem of joining the outputs together after seperate bridge rectifiers per transformer.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#4 |
Hook them up in series and use full wave rectification.
#5 |
thanks for the help guys .what exactly will the bridge rectifiers acheive i thought a rectifier changed ac to dc ? my power supply boards already do this
| toroid ID help | BeerCan | Power Supplies | 2 | 24th May 2011 11:38 PM |
| Toroid? | billbeau | Chip Amps | 3 | 4th November 2008 03:26 AM |
| Trade a 40V 400VA Toroid for 20V 300VA Toroid | john65b | Swap Meet | 7 | 10th October 2006 03:49 AM |
| Toroid @ PE | troystg | Chip Amps | 23 | 20th January 2005 06:50 PM |
| What amp for this toroid ?? | Ford_V6 | Solid State | 3 | 5th July 2003 10:53 PM |
| Page generated in 0.07895 seconds (72.53% PHP - 27.47% MySQL) with 11 queries |
