connect to circuit with different ground level
Old 23rd April 2008, 03:15 AM   #1
jegandren is offline jegandren  Malaysia
Send a message via Yahoo to jegandren
Default connect to circuit with different ground level
Dear all,
Anyone has an idea to connect two circuits with different ground level.
Many Thanks
Old 23rd April 2008, 03:22 AM   #2
Iain McNeill is offline Iain McNeill  United Kingdom
diyAudio Moderator Emeritus
Iain McNeill's Avatar
Transformers would be the preferred way although you can sometimes also couple with caps depending on the voltage difference and the circuits you are connecting.
Optical is another coupling method, although usually more complicated.
Why are your two grounds so different? Are there any safety issues that should be considered?
Old 23rd April 2008, 03:32 AM   #3
Thank you very much for your reply.....actually the isolation is for safety reasons...i guess ill consider the transformer coupling technique.
Old 23rd April 2008, 03:42 AM   #4
Yes, transformers for safety! remember to use the peak voltage not the RMS voltage when determining the withstand voltage for primary-secondary. I always like to double it but then I'm scared of electricity
connect to circuit with different ground levelHide this!Advertise here!
Should I directly connect my signal ground to chassis ground? Bricolo Solid State 4 18th March 2014 10:42 PM
Ground field on pcb - how to connect ? GrzMiL Parts 2 31st December 2008 07:01 PM
StarGround: where connect the ground pin of the Volume Pot ygg-it Chip Amps 1 19th May 2008 01:55 PM
How to connect ground plane to via using Eagle? Ipanema Everything Else 5 23rd October 2006 09:16 AM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 01:55 PM
Copyright ©1999-2017 diyAudio
