is there any simple way to rise DC voltage by a few 10th of volts? I sometimes run my laptop from a 12v SLA battery, using a car/home laptop power adapter. I can get about 2.5 hours from a 7Ah SLA battery, but I should be able to run it for at least 4 hours, considering the original LiIon 4Ah battery (now lasts 20minutes) originally worked for 2.5 hours. I'm under the impression that it's caused by the fact that the adapter runs from a minimum DC voltage of 11.75V, and that the battery is supposed to be empty at about 11.4V. Would there be a simple way to rise the voltage a bit to get a few extra hours out of the battery?
Antoine http://dmsaudio.ca/ |
#2 |
Erm,Not really..
I suppose you could make a SMPS that took a 10-13V input,and output a regulated 11.75V or whatever voltage is required. It may not be the most efficient SMPS ever,but might be do-able. Can you reduce the load at all? Any unused hardware connected? Remove any PCMCIA and USB devices when they are not in use. Perhaps stick a flexible solar panel on the back of the screen? It could trickle the charge the battery a bit,would give you a bit more runtime,and help keep the battery voltage up a tad bit more? (Flexible) solar panels are kind of expensive,so this may not be very practical. Edit: One other thought,If you are using wires to connect the battery to the laptop,you could try bumping them up (down,really) a few sizes. Heavier wire will have less resistance (loss) and you might gain a bit of voltage,if your wires are really small. |
#3 |
I guess you could make a SMPS that takes 12 Volt input and provide only a few millivolts at the output, and connect it in series with the battery?
#4 |
Make a simple dc-dc powersupply that gets 24V, then regulate down to about 13-14v your choice, that way you are sure to have enough voltage.
Any 12V push-pull smps primary always has 24v on it. You could get a cheap toroid choke, wrap just 10+10 turns of thick wire, do push pull and get the 24V. No secondary winding needed. |
#5 | |
If he doubles the voltage and then regulates it down, will surely half the capacity. |
| beta 8a rising response? | AudioGeek | Full Range | 1 | 27th April 2009 08:45 PM |
| Is high frequency rising-up OK? | Peter Huang | Pass Labs | 3 | 4th August 2007 10:32 PM |
| Rising hum when turntable is plugged into preamp ?? | Shoog | Tubes / Valves | 12 | 6th November 2006 10:54 AM |
| How would you aproach this rising frequency response? | swak | Full Range | 6 | 4th November 2004 08:30 PM |
| Handling a rising response | rick57 | Multi-Way | 7 | 12th March 2003 09:53 PM |
| Page generated in 0.07360 seconds (82.06% PHP - 17.94% MySQL) with 10 queries |
