Indestructible HV hybrid regulator!
Old 20th April 2008, 10:40 AM   #1
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
Default Indestructible HV hybrid regulator!
After months of experimenting and trial and error I finally managed to arrive at a working prototype of a hybrid regulator. It is based on a new HV opamp made by texas, OPA454. The prototype is capable of 1 A, yes 1A at 220V with less than 1,5mV ripple fully loaded (resistive load), which is more like random noise on my scope.
One problem I noticed is that when the speed-up capacitor (470n) is out of the circuit the power suplly is unstable producing a steady 5-6KHz oscillation.
Otherwise the circuit is very stable and there is no measurable drop in output voltage from no load to full load.
Another problem I noticed when used this is powering a 6W SE tube amplifier at 238V/200ma at full output power, is that the AC component on the power rails, when sweeping from 5Hz to 20KHz is not uniform, but changes from 1mV@5Hz-1Khz to 30mV@20KHz.
Is this non uniform responce acceptable, or the regulator is suffering some kind of problem?
If this is a problem, is there anyway I can fix this?
Any comments or suggestions are very more than welcome.
Old 20th April 2008, 11:37 AM   #2
woody is offline woody
How long did you test it at 220v and 1A? It looks like to me that
you would be droping about 140v across that 6c33c. At one A that
would be 140w and the tube is only rated at 560ma and 60w!
Old 20th April 2008, 02:07 PM   #3
panos29's Avatar
Default Correct
Very correct, I only did that test for less than 20 seconds to see the limits of the circuit. However, the tube did not get red duing the test period, its anode is massive tiatanium made and it is very hard to get it to glow. It is an amazingly tough tube that can take alot of abuse! I even tried a direct short, 3 times, in order to test if it is shortcircuit-proof (the bang was spectacular!).
Indestructible HV hybrid regulator!Hide this!Advertise here!
WTB - pair or current regulator diodes for millet hybrid mekanoplastik Swap Meet 11 8th March 2011 07:06 AM
Tube Hybrid Shunt Regulator ... will this even work? dsavitsk Tubes / Valves 8 19th July 2009 09:50 PM
Indestructible HV hybrid regulator! panos29 Tubes / Valves 5 23rd June 2008 12:12 PM
Hybrid regulator diegot Tubes / Valves 0 9th April 2008 04:02 PM
My wacky idea for a hybrid horn loaded woofer/planar widerange hybrid loudspeaker. Spasticteapot Multi-Way 0 30th November 2006 04:16 AM
