Designing single supply audio - what best way to get a clean reference ground?
Old 15th April 2008, 10:47 PM   #1
azone is offline azone  United States
Default Designing single supply audio - what best way to get a clean reference ground?
I haven't done much with a single supply, the job I'm working on has some restrictions.
The circuit is actually powered from an AC supply, not batteries, so the voltage regulation is not perfect. The main positive supply is an LM317. The output is 10V, the voltage regulation is probably about 4mV or so. This is fine to power all op amps and other IC's, transistors.
I'm not sure if it's feasible to split this 10V supply to derive a 5V bias voltage to use as the ac ground. I'm not sure how clean this virtual ground needs to be. The circuit is all pre-amp stuff - with signals in the range of 20mV to 1V.
If my virtual ground has 4mV of ripple in it isn't that going to effect my circuit by causing a lot of distortion?
or is it not really that important/audible?
Would you get a better reference by using a 5V reference diode like an LM336Z-5.0 (since it's dereived from ground and not the shaky positive supply)?
Old 15th April 2008, 10:53 PM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
Which ever way you go, you'll bypass your mid-voltage to ground with a good size cap, so the ripple and noise should be microvolts, not millivolts. Naturally the reference will be better, but you still need to bypass it to kill noise.
I may be barking up the wrong tree, but at least I'm barking!
Designing single supply audio - what best way to get a clean reference ground?Hide this!Advertise here!
Creating the 'virtual ground' in a single supply preamp/amp circuit??? DoiNk! Solid State 21 19th September 2016 12:43 AM
Single Supply LM3886 - better virtual ground turantual Chip Amps 2 8th August 2008 09:39 AM
Ground reference mashaffer Tubes / Valves 8 29th February 2008 12:54 AM
Battery PS: Virtual ground or single supply? Dominique Power Supplies 2 6th May 2007 12:34 AM
Designing a Reference Speakers - 4 Way Active HiFiNutNut Multi-Way 11 6th June 2004 06:01 AM
